Are these CDs that you burned yourself? Older CD players won't recognize the audio file format of this kind of recording, only the established file format that typical retail CDs have used for years. In recent years, CD players have been developed to recognize more file types than just the old format; but with an older player like you have in your car, it wouldn't recognize what you were trying to play, as if you put a DVD in. It balks, and spits it out. You can burn CDs with the correct file format, you just need the appropriate software or file translator.
There is no easy answer to this. I know that I have problems when I burn CDs in any format using my computers DVD burner. Fortunately I also have a regular CD burner which seems to do a much better job. It may also be the CD player needs to be cleaned, seems that MP3 capable CD players are more sensitive when playing MP3 discs as opposed to regular CDs. There is really no other format that is widely supported (other than WMA) that will give you the capacity of a MP3.
you have to download a program or a software that plays or are able to read dvd file formats inorder for you to play your desired format. try to download vlc media player
Hello there:
you might need to check to see the format of the dvd that you are trying to play ie dvdr vice dvd some devices will not play them if the format of the cd is wrong
No Disk issues on device players like DVDs are caused by the following problems
Dirty Play Heads (Optical lens)
Bad CDs or scratched CDs on the surface
Non Compatible CD formats such as DVDs that are designed for some geographical regions and play formats
Also low electrical current is a major problem too
Your issue could reside amongst any of these problems
Check your DVD compactible play formats if its compactible with the CD you want to play.
If its compactible, then I suggest you get a CD Cleaner to clean to clean to Lens.
Also check your current output and if low, get a voltage stabilizer
Check the surface of the CD if its scratched and get a replacement.
Please note that the formats of DVD and CD are quite different. Whereas a DVD drive can handle both DVD and CD, a CD drive can only handle cd formats. Furthermore, a drive that reads both formats does not necessarily mean it can handle the writing aspect ok. You need a drive that is capable of writing/burning DVD. Most drives that come along with pcs can only write CDs but able to read both. So check your drive to see whether or not it can write on DVDs ok. Good luck
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
You might be able to convert them to DVD-Video format if you've got a DVD burner
and the right software.
Another possible option would be converting them
to a Video CD/Super Video CD if the DVD player can play Video CDs or Super Video
CDs and you have a CD burner and software that can burn VCDs/SVCDs
