Question about Teac SL-A100 Turntable
Stopped turning The turntable suddenly no longer turns.  Everything else seems to be working fine and the phono feature itself works except for that it doesn't turn when the needle is in the correct position
  • 2,130 Answers
Try removing the cover and looking for a broken belt. Make sure that the motor is spinning too. If you find a broken belt, let me know and I'll help you find a replacement.
- Jim
Posted on Jan 28, 2008
    SHARCNET-USA Jan 28, 2008
    ** Always remove the power plug from the wall outlet when taking the cover off ** .
HELP: Stopped spinning
It's likely the belt has slipped of and probably needs replacing. You can do this yourself. It will be found under the turntable matt. The trick though is fitting it back on. But you might find the instructions on-line (enter the model number into google search). Some people have even put YouTube video's on how to replace the belt on popular turntables.
Jun 11, 2014 | Crosley CR74 Turntable
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
Although my turntable seems to be fine there is hardly any sound coming through my amp/speakers from it. I'm using a different power lead for it since I've lost my original but it fits fine an
your needle has worn down, or the RCA leads(red & white) arn't plugged in to the phono socket on the amp,or you haven't selected phono on the source select,or you have the tape monitor button switched on.
Jul 07, 2012 | Technics SL-BD22 Turntable
Turntable has new needle but will not play
if wires and needle are good is the rca jacks in a input phono aux are the ones to use and the amp is set to aux or phono is the ground wire in ifit isnt working then its more likely the cartrage is shorted out thats the metal box that the needle is connected to
Jun 05, 2012 | Marantz Audio Players & Recorders
Half the signal only through left speaker
Try the switch in the other position and see if that fixes the problem. some turntables had a phono level that is different than a standard rca line level input. Also try a different cable if the rca is not hardwired in to the turntable. The cable could be bad. If worse comes to worse upgrade to another amplifier or tuner that has a separate phono input. hope that helps.
May 09, 2010 | Stanton T.120 Turntable
My combination CD/Cassette Phono turntable doesn't turn. THe CD and Cassette work fine and the phono pickup is working.
As the belt broke or come off. You might need to lift/detach the turntable matt to find out.
Aug 28, 2009 | Audio Players & Recorders
No sound from CDJ-800 MK2
Are you getting error messages? Running in thru LINE? Is not on mute? The possiblity of both not playing would lead to process of elimination.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-800 Turntable
Teac SL-A100 Turntable Logo
232 people viewed this question
Top Teac Audio Players & Recorders Experts
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
