My Canon IP3000 has power but cannot print. What should I do?
Canon IP3000 INK counter reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
All The Best Pineworks
SOURCE: The HP Designjet 1055cm has
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
SOURCE: Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
SOURCE: Won't recognize color ink cartridge
This is a common problem with Kodak 5000 series and ESP series printers.
Check the silver contacts on the ink cartridges for small scratches in the center. The scratches indicate that the ink cartridges have made contact with the appropriate connections in the printer. If no marks are visible, the cartridge was not seated properly. If the contacts look ok, you'll have to call Kodak again. It's highly likely that the recertified printer you received was returned for the same problem. If you point out the fact that you are experiencing the same problem for the second time, you may wind up with an upgrade to an ESP5. Don't accept another printhead replacement as thiat will not resolve the problem.
SOURCE: Kodak 5300 shows
Try this one
Take out the inks and printhead
Leave the cartridge door open, then unplug the power cord from the back of the printer while the access door is open
Close the cartridge door once the cord is unplugged
Reconnect the powercord, turn on the printer, then your printer will look for your printhead "Printhead missing or not installed correctly..."
Then put everything back. make sure it will snap in to place. Then print a calibration page, then scan it. This is just over writing the error message.
Thanks Josh - Kodak Tech Support
Testimonial: "I will give it a shot when I get home..Thanks.."
SOURCE: The screen says : Printhead missing, not installed
Printhead is faulty > Needs to be replaced
call kodak aio support and get a free printhead replaced
