I have a 1990 Mitsubishi tv. I am trying to hook a dvd player to one of the ext inputs and it is telling me that the ext is locked and I must enter a passcode to use it. I have never used it before and never have put in a passcode it is a model VS_6015R help me
  • 2 more comments
  • Dan Finlinson
    Dan Finlinson Jan 28, 2008
    WHAT IS qv?
  • Dan Finlinson
    I can not find a qv on my remote, now what do I do?
  • Dan Finlinson
    Dan Finlinson Jan 29, 2008
    Yes I have original and I found the button, it was covered in 19 years of dirt. I tried your suggestion and the screen got dim but no instructions came up.
  • Dan Finlinson
    Dan Finlinson Jan 31, 2008
    Yes, I pushed qv and 9 and no instructions are comming up. Now what can I do?
    Dan
    President:
  • 4,402 Answers
Try this
push qv and 9 on your remote and a screen will come up and follow the directions to correct your problem.
Posted on Jan 28, 2008
  • 1 more comment
  • Cary Farah
    Cary Farah Jan 29, 2008
    it's under the scan button, do you have the original remote?
  • Cary Farah
    did you push push qv and 9?
  • Cary Farah
    Cary Farah Jan 31, 2008
    call mits 800-3322119
I have a Mitsubishi WD-62525 TV with a Blue Ray DVD player hooked up to it. When I play a standard DVD, the picture is fine but if I play a Blue Ray DVD the picture is scrambled. I hooked the same DVD...
Might be tuned to the wrong output. The big tv has more than one input and is select able. Is there a blue ray selection for TV or input for that device.
Aug 09, 2014 | Mitsubishi WD Televison & Video
I have a Mitsubishi WS-65513 65 in. rear projection HDTV. I recently hooked up a DVD player to the Component 2 cable inputs but I cannot find the Component 2 selection on the 'Device menu' to tell the TV...
If one or more of the inputs is "missing" or not there you may need to do a hard reset of the TV with the original remote.
If you want to try this confirm the actual model number and I will tell you how to do it.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65513 65" Rear Projection...
I just bought this tv ws-55613 from a friend, when I looked at it i hooked up a dvd player and it worked great.after igot it home, i hooked it dish network. It worked fine until i started to play around...
This is 2003 model and does have a hard reset. It will return set to as it was when new in box, on air band on channel three, most likely you did something with remote that changed something.
I am in California and can tell you how to with the set on with the Mitsubishi remote enter the OPTION MENU AND RESET IT.
DO YOU WANT THIS INFORMATION?
A VERY HELPFUL RATING IN RESPONSE TO THIS SOLUTION WILL TELL YOU HOW TO GET INTO THE OPTION MENU.
SD TECH (in San Diego)
Aug 22, 2010 | Mitsubishi WS-55613 55" Rear Projection...
When I hook my dvd player up using the Component Video Input I get sound, but no video. Its not the dvd player because i hooked it up to my other tv and it worked fine. Thanks for any assistance
This might be the other TV's Video Input Cable Plug. Could be disconnected somewhere within, it may be disconnected. If your TV has two slots for Audio/Video Input, try using the other Slots maybe. :)
Apr 02, 2010 | Mitsubishi VS-60607 TV
How do I change my remote for TV to Input Video 1?
There should be a button on your remote denoting "Input." If you connect the DVD player to the TV on "video input 1" then push the input button on the remote or TV itself until the DVD appears on your TV (which will be Video 1). Some TVs must have the component (in your case) the "DVD" player connected to the TV before the TV will recognize it. Make sure the DVD is powered up and then push the input button until the DVD player appears on the TV. Depending on your TV inputs, there may be multiple inputs like, Video, Component, DVI, or HDMI. The above are listed in the respective order of "quality." HDMI being the best. Whatever input you hook the DVD player up to on the TV will be the "input" you will look for when pressing the input button. Hope this helps.
Oct 26, 2009 | Mitsubishi WS-48515 48" Rear Projection...
Don't know which input the matches which device icon on screen
if you look on the back , the inputs are labled, then go into the tv menue and go under device lable and match the input it is plugged into, to the dvd icon
Jan 07, 2009 | Mitsubishi WD-52525 52" Rear Projection...
My Mother has the VS-5003R big screen television that she purchased back in 1990. the television portion works fine but the ext-1 and ext-2 inputs are locked from a code that probably died with my father...
I have the same tv and same issue. I found chain of notes indicating that you can clear the lock by pressing 9-QV (two buttons) on the original remote at the same time. This works... however if you change the input again the EXT1 and EXT2 inputs will be locked again. It would be really nice if you can remove the lock feature completely.
Aug 07, 2008 | Mitsubishi Televison & Video
Mitsubishi tv
I found this online somewhere and it cleared my problem.
(my problem was a blue screen that said my input was locked enter in your code using the 10 key pad. Both inputs were locked, I used the steps below and it cleared it. We are now watching a dvd for the first time in months!) Thank you Bob Waterman whoever you are!)
MITSUBISHI CS3114R
Parental Lock
This system can lock each channel or different channels on ANT A and ANT B
as well as locking each of the EXT inputs, so you should confirm what is
locked before trying to unlock.
1 On the remote, set the TV/VCR switch to the TV position
Or . Depending on which remote is being used
Press the TV mode button at the top.
2. Turn on the TV and using the SCAN buttons (or 10 KEY FAD) and the INPUT
buttons check each channel and input to establish which channels and inputs
are locked. The screen will tell you if the channel or input is locked.
3. Press the button labeled MENU. The screen will show the main TV menu.
4. Press the #5 button (channel lock option).
The screen will change to show the channel lock System Menu. This screen
will indicate that the lock system is either ON or OFF.
IF THE SCREEN INDICATES LOCK IS ON, GO TO STEP 5
OR:
IF THE SCREEN INDICATES THE LOCK IS OFF, GO TO STEP 5A
5. Press the #3 button. (SELECT CHANNELS TO LOCK option). The screen will
ask for the code number. Press the #9 and QV buttons at the same time.
Notes: The screen will change to show an information display that will show
the selected antenna and channel or input. The display is superimposed over
the picture. This display will indicate that the channel or input is either
locked or unlocked. In the lower middle will be instructions to use the
10-key pad or SCAN buttons to select the desired channels (or the INPUT
button to change antennas or select the EXT inputs). At the bottom of the
screen will be instructions on how to change the current LOCK status (if
unlocked use the ENTER button to lock, or if locked use the CANCEL button to
unlock).
NOW GO TO STEP #6.
5a. Press the #1 button (channel lock ON option). The screen will ask for a
code number. Use the 10-KEY PAD to enter a new code number (We suggest 1111)
and then press the ENTER button.
unlock).
NOW GO TO STEP #6.
6. Use the 10 KEY PAD or SCAN buttons to select the channels that are
locked, or, use the INPUT button to select the external inputs that are
locked.
7. At each locked channel or input press the CANCEL button.
The screen will indicate that the channel or input is either locked or
unlocked.
8. When all of the channels and/or inputs are unlocked, press the MENU
button again. TV main menu will be displayed.
9. Press the #5 button (CHANNEL LOCK option).
10. Press the #2 button (channel lock OFF option). The screen will now ask
for a code number again.
11. Press the #9 and QV buttons at the same time. The screen will return
to the CHANNEL LOCK MENU and indicate that the lock is OFF
12. Press the MENU button twice to return to normal viewing.
The parental lock is now entirely cancelled.
Bob Waterman, CET® #RI-28
Master Technician License #9109
Service Manager / Parts Manager
Gemini Computer, TV, & Security Alarms
(508)695-7302
(508)695-7769 FAX
geminitv@xxxxxxxxxxxxxxxx
geminitv@xxxxxxx
www.geminicomputertvsecurityalarms.com
Nov 18, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Locked ext inputs
I'll give you the master reset, with set on, and from the remote hit Menu-1-2-7-0 this will bring up the Intilize screen and the word Initlize should be highlighted, if it is hit enter on the remote, this is the factory default settings so now if the set ask for a parental code it will be 0000
Nov 06, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
