Question about Zenith D60WLCD 60" Rear Projection HDTV-Ready Television
Blue screen probelm on my projectıon tv 52 '' VESTEL AKAI
My tv gettıng started to be blue screen.I mean I dıd adjust all settıngs but ıt never cahnge some how.It was very normal but now screen more more blue tone .Please tell me why and what I need to do before I go to servıce ??? Thank you for your help.
    Champion:
  • 208 Answers
This is a chronic problem with this unit and the failure is the lcd optic block (light engine). This part is only available rebuilt and cost of the engine alone is around 500.00 and this does require a service professional.
Posted on Feb 10, 2008
Akai 52" rear projection...colors are off and screen is washed yellow
Sounds like the blue gun has died. I would say that you should call Salvation Army and have them collect it for you and buy a new LED flat screen TV to replace it.
Aug 02, 2012 | Akai Televison & Video
Picture looks like triple vision
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | RCA D52W23 52" HDTV CRT TV
Blue, red and green are separated and i cannot find convergence from main menu
Sep 22, 2010 | RCA P52939 52" Rear Projection Television
Horizontally the picture is distorted (doubled). Sound is ok. we have a 52 inch RCA big screen tv.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Feb 21, 2010 | RCA P52926 52" Rear Projection Television
I have a 52 inch RCA projection tv. Where are the color adjustment screws on the back of the tv that everyone keeps telling me about?
This is Chassis PTK195-There are screen/focus adjustment knobs (red green and blue) at the front of the set - behind the speaker grill and front access panel.
Oct 11, 2009 | RCA P52926 52" Rear Projection Television
Curved red image on 46" Akai rear projection TV
Yes! an idea that the flyback transformer is shot!
Please rate our help to keep the free service online
Aug 29, 2009 | Akai PT4298HD Rear Projection Television
Rca 7302rd5 56"hdtv tv looks like a 3d moive
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 03, 2009 | RCA R52WM24 52" HDTV Projection Television
SONY KP53HS30 rear projection TV screen suddenly turned blue....
The blinking 5 times is an error code meaning that the white balance has a failure. And because you are experiencing a blueish screen then your problem lies in the circuit of the blue picture tube or possibly the blue tube itself is starting to go bad.
C-Dog
Feb 05, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
WD52525 had a blue screen when turned off
Perfect Blue screen usually means video problems. Leave unplugged and try again to make sure.
Aug 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Logo
104 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
