Our Dimension 3000 stopped booting up (blue screen "unmountable boot drive" error). I did the Dell system restore procedure which reverts hard drive to original, out of the box condition. Worked fine for 1 day then got blue screen again. Attempted reformat from system disk provided by Dell, it progressed to about 5% and I got "error caused by file: partmgr.sys. Any suggestions? I am a novice at this, but good at following directions!
Thanks so much, Bev
Your hard drive is bad, order a new one they are cheap, throw the new hard drive in which is easy and then boot from the repair cd and your computer will survive. I believe your computer takes an IDE hard drive so don't order a SATA one unless you look at the cable connecting the drive and it is way smaller than the other wide ribbon cables in the case.
CHANGE THE RAM MEANS YOU GET ANOTHER RAM(MEMORY) AND TRY INSTALLING IT
Please re partition the hard disk and install the operating system. if the same error continues then change the ram and try
What do you mean "change the ram"??
Thanks! Bev
dell dimension 400 has unmountable boot volume
