Question about Vacuums
How do I remove a motor from a Dyson DC04? The bottom plastic cover can be removed by unsrewing the tork screws but the cover beneath the filter won't come off
  • 103 Answers
I can't say exactly how to do this, but when you can't find the screws to take something apart, they are usually hidden by something else. You did good looking under the bottom cover, but what you're looking for is elsewhere. If there is a seam or line around the middle where it looks like two halves fit together and you can't find anymore screws, use a flat blade screwdriver and GENTLY start to pry them apart to see if they start to separate. If it doesn't give easily, don't force it. Many times a cover will snap into place and then is held secure by screws.
Good luck, and please remember to rate this. I want to know if this helps at all.
Thanks, and good luck!
Posted on Feb 04, 2008
How do you remove dyson dc04 absolute start switch
The switch is in a cover held on by screws and tabs. Remove the hose and wand to gain access to the screws and tabs. After removing the screws, push on the tabs to release them and the cover will come off the front of the machine. Be very careful removing parts so you will know how to put them back together.
Jul 10, 2014 | Dyson DCO7 Animal Bagless Upright Cyclonic...
How can i remove a switch cover to a dyson dc04
Hi, it's Cindy from Crucial Vacuum.
It is possible to replace the DC04 switch. Unplug your vacuum and remove the cyclonic assembly on your vacuum. Using a screwdriver, unscrew the switch cover. You may need to shimmy the switch cover off then the old switch is easily removed from its connectors and the new switch can be connected. Screw the cover back on and place the cyclonic assembly on and your done!
You can purchase direct your replacement switch from Crucial Vacuum with free shipping and an exclusive 10% coupon for viewers, use code: FIXYA10
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 26, 2014 | Dyson DC18 all floors Bagless Upright...
Smelly Dyson DC04
Hi Philip,
I'm sorry to hear you're having difficulties with your DC04. If the machine's making an unusual smell, we'd advise against running it again. I'd encourage you to get in touch with us directly so we can help resolve this.
You can call us on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week.
We'll look forward to hearing from you.
Best wishes,
Dyson Online Customer Support
Mar 10, 2012 | Dyson DC04 HEPA Bagless Upright Cyclonic...
My DC04 showed signs of motor belt broken. This has been confirmed by following the dismantling video for DC07 for my DC04(with some differences). Have got to the clutch removal stage but cannot get it to...
Assuming you have removed the 3 screws that cover the clucth cover and removed the clutch cover, and assuming yo have taked the clutch knob off, all you need to do is grab the rubber belts and give it a good tug
Feb 02, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I remove plastic cover plate over the switch assembly within a dc04?
Have a look at which has some great info on your machine.
Aug 21, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Dyson sell a bent screwdriver.....
.... to make it easier to remove the switch cover:
I have used an ordinary screwdriver pushed into the tiny gap between the flat side of the switch cover (see picture above) to force the 'tooth' away from its housing, and then pull cover off.
Underneath is a torx-headed screw, which when removed allows withdrawal of the switch assembly.
Jul 28, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
My belt has snaped on my dyson dc04 that has a clutch how do i change it
Remove the roller brush cover plate that is on the bottom and you will be able to access the belts. Here are the belts you need:
Dyson DC04 Belts
Nov 18, 2009 | Vacuums
Dyson DC04 is making a grinding sound & smells of burning. Hi. I have been told that the above is due to the carbon motor brushes burning out. The brush at the bottom still turns ok. I have bought 2...
Hi there SmartAlec from here, this is not a repair for the faint hearted. First i am assuming you are not using a clutch model - with a selector for carpet/hard floor on the side. If you do have that model i can give you extra instruction. First you will ned a torx driver (like a phillips head but with a star) size 15. Remove the clear bin, the hose that runs up the back of the vacuum and the filter cover and filter. Also remove the inspection tube at back of machine and anything else that pops off easily.
Next turn the dyson dc04 vacuum cleaner upside down and remove the base plate this is done with a large flatblade screwdriver.
The next step is the brush - you should be able to access the drive shaft and pull the belt off which will free the roller.
Unclip the small hose which goes from soleplate to the back of vacuum and remove the soleplate itself you will need to apply very firm pressure and only pull each side out a little way because if you go too far you will crack the guide.
Next is to remove the housing that holds the whole brush assembly. You will see on either side of the vacuum 1 plastic washer (like a circle with a bit taken out) which has to be removed. Once both are off you can gently slip off the body over the shaft that the washers held the body on to. This removes the the body part that moves up and down to adjust your dyson to different height carpets.
Now you should have basically a "nude' dyson
Next step is to remove the 8 torx screws that are spaced around the motor housing. The plastic outer will now come away revealing the last bit of motor casing.
There is a cover plate that is held in by 4 lugs that can be gently pried back with a small screwdriver and the lid will come off like a tupperware container.
From here your on the home straight.
The motor now needs to be pushed out of its little case. The large rubber gasket will make this quite hard as it it designed to hold the motor in but with a fair bit of pressure it will slide out.
With the motor out it should be easy access to the carbon brushes they will simply screw off allowing new ones to be screwed back on.
Reversing the process is as simple (after youve done a few) as reversing the instructions and keep in your mind if you have to apply a lot of force it is likely that something is not lined up properly.
Hope this helps. if you need more tips hit me on the website
Aug 25, 2009 | Vacuums
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
