Question about Mitsubishi WD-65833 65" HDTV
Net Command Does not work
I have a Mitsubishi WD-65833 and I cannot get the net command to work correctly. Mitsubishi support is absolutely worthless. I can read the manual my self. I don't need someone to read it to me over the phone.
I am trying to set up net-command to control my reciever. I can get it to learn the codes of my reciever. When I turn off the TV it turns off the reciever, but I cannot get it to send any other commands to the reciever. If I could just get it to correctly send the correct input that the reciver should be sending I would be happy.
Go to net command menu click on the AVR Learn icon.
Now you can program 4 different functions (inputs) from another remote. I programed 4 different source settings from my A/V receiver. And you label each input appropiately. Such as DVD, SAT, CAB, ANT.....
Now go back to net command and just to the right of previous Learn Icon you input the name of the source you just programmed for which ever device it is currently watching.
Net command is very confusing but works great once you figure it out. Hope this helps.
Posted on Feb 08, 2008
Wd-65833 has black spots
This is the DLP chip failing. Contact Mitsubishi and they will provide the part but you have to pay $200 for the service call.
Apr 17, 2012 | Mitsubishi WD-65833 65" HDTV
Tip
How to stop the Annoying Windows Automatic Updates Restart Dialog box
YOU CAN TRY THE FOLLOWING STEPS TO DISABLE AUTOMATIC UPDATE SERVICE.
  • GO TO START-RUN
  • THEN TYPE CMD CLICK OK
  • IN THE COMMAND LINE TYPE THE FOLLOWING COMMAND AND HIT ENTER
  • "NET STOP WUAUSERV" COMMAND (LESS QUOTES) TO STOP IT
  • AND "NET START WUAUSERV" TO START IT.
  • WINDOWS XP USERS HAVE TURNED ON AUTOMATIC WINDOWS UPDATE WILL HAVE ABSOLUTELY NO PROBLEM
  • RECOGNIZING THE "RESTART NOW, RESTART LATER"
  • THE EASIEST WAY TO STOP THIS ANNOYING WINDOW IS TO START WINDOWS COMMAND PROMPT (START -> RUN -> CMD)
  • AND TYPE THE FOLLOWING COMMAND:
  • SC STOP WUAUSERV
  • AND THEN HIT ENTER.
  • THE RESTART WINDOW WILL DISAPPEAR IMMEDIATELY INCLUDING THE ICON IN THE SYSTEM TRAY.
on Feb 19, 2011 | Computers & Internet
Channel button does not work on tv
Net Command usually means it is Mitsubishi ----are all buttons on front of set except on and off locked out or do not function?
On most of the sets made by them if this is the case hold the MENU BUTTON ON THE FRONT OF THE SET IN FOR 8 SECONDS AND RELEASE to unlock the front keyboard.
Apr 05, 2012 | Mitsubishi Televison & Video
I have a mitsubishi wd 65 837 and it has white and black spots on the left side of the tv , can it befixed ?
I just had this happen to my wd-65833. It is a faulty dlp chip (they call it dmd board). I called Mitsubishi and they covered the cost of the part but there is a $200 service fee for the technician, no they will not send it to you. Support Service Mitsubishi TV
Sep 06, 2011 | Mitsubishi WD-65833 65" HDTV
I have a Mitsubishi Medallion HDTV Integrated 1080 WS-65615 and the speakers wont work. I've tried the the whole speaker/audio stuff but it wont let me select tv speakers.... help please!
hummm if i may suggest something... do you have net command enabled this would disable the speaker selection giving control of audio to other devices.
Oct 15, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Need help with Harmony One remote and Mits WD-65736
To ensure the remote controls your devices properly, you must disable Net Command.To disable Net Command you must delete all devices associated with it.
Open the Mitsubishi Television's setup menu.
Select Delete at the setup menu.
Select Entire Configuration and then select Next.
Follow the onscreen instructions to delete the entire configuration.
To finalize your selections and complete the NetCommand setup, select Finish from the finish screen.
#messageContent0_1 {font:10pt Tahoma,Verdana,sans-serif;}
Feb 01, 2010 | Mitsubishi WD-65736 Television
Picture but no volume
I went to menu then press net command and press audio then enter. Then I press the arrow up on the adjust key and switch it from AVR to TV/Video.
Jan 06, 2010 | Mitsubishi WD-65731 65" HDTV
I have a wd-52525 mitsubishi and it is supossed to be 720p but when I turn it on it says its 480i. What part of the tv makes it 720p or 1080p? Please help.......Thanks Paul
You will have to use component inputs for above 480i, and use the FORMAT key on your remote control unit (lower panel in center) to change to whatever you want for resolution. Be sure you have your signal input set to one of the Component inputs via Setup or Net Command (or use Devices on the remote)
Jul 19, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-65833 65" HDTV Logo
650 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
