Question about Panasonic KX-FHD351 Plain Paper Thermal transfer Fax
When I send faxes the reciever gets a different fax caller ID
I have recently bought a Panasonic FHD351 off of Ebay. And I sent a fax and the person I sent it to told me it said the last owners name. Is there a way I can change it to my name?
  • 63 Answers
Ring 13 2600. Tell them you bought it (NOT SECOND HAND) and you lost the manual, Explain the problem and they should give you an answer for free!
Posted on Jan 29, 2008
SOURCE:
Print missing from one side of image
Check the film if inserted properly, or the the film is got damage one side
Oct 18, 2011 | Panasonic KX-FHD351 Plain Paper Thermal...
My Panasonic kx-fhd351 won't feed paper to receive a fax.I assume I need to clean something, but I am not sure what and how.
Does this model also act a copier? If so does it make a copy? If so mite be fax issue. Use alchol to clean rollers, remove draw and clean them.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 15, 2009 | Panasonic KX-FHD351 Plain Paper Thermal...
Clean Fax KXFHD351 Panasonic
Nope No mirror, try cleaning the drum corona wire. Gently clean wire with a #2 pecil eraser to remove any dirt, then open fax sheet feeder and GENTLY clean with alcohol wipe across the light bar scanner. Paper dust builds up on this.
Jul 08, 2009 | Panasonic KX-FHD351 Plain Paper Thermal...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Fax Memory Full
Have you tried you u n plugging power cord and plugging back in?
Sep 26, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Panasonic kx-fp 342 papaer jam
paper jam or missfeed always due tothe following:-
1-malefunction of paper feeding system due to broken gears belt chain please check smoth mechnical movement and apply light grease in gears and change any broken part.
2-something is blocking the paper path (staplers-pins)droped inside.
3-malefunction of paper detection micoswitch please confirm free operation for the lever in mechnical one and clean of dust and dirt from optical one,
Mar 06, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Panassonic KX-FHD351 paper problems
something in the way: paper, paper clip or tires not picking up paper. Clean with alsohol then try.
Feb 11, 2008 | Panasonic KX-FHD351 Plain Paper Thermal...
Paper problems ><
try cleaning the tires with alcohol
Faulty fax machine
You can try cleaning that roller with a rag and some rubbing alcohol. Scrub it really good all the way around and that should help.
Aug 02, 2007 | Panasonic KX-FHD351 Plain Paper Thermal...
Panasonic KX-FHD351 Plain Paper Thermal transfer Fax Logo
79 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
