I am having to use an external keyboard because some of the letters I push are not what I am selecting other characters appear incorrectly. Just U, I, O, P, [, 0, ....Then all of sudden my backspace button erases what I am typing
Oh please don't tell us what router, remote or anything else that would actually help find a solution to your problem. We'll just sit here and ignore your question.
On the L. of the keyboard there is a slide switch for pitch it should be in 10, 12 or 15 not in PS. If it isn't in PS push down on it and slide it up and down a few times and leave it in 10 or 12.
Your numlock is turned on. There is more than one way to turn it off.Find a USB keyboard, and plug it in. Then push the numlock key on the USB keyboard to turn it off.OR, if you don't have access to one of those, hold down the fn key (lower left hand corner of the keyboard) and press the key with numlock or number lock written on or near it.
Try cleaning the keyboard with a clean, dry paintbrush just in case there is anything stuck under the keys. Once you have cleaned the keyboard try typing keys to see if it does the same thing. If the keys type as normal then you have resolved the problem. If the keys still type other characters along with the letter then there is a strong possibility that the keyboard needs to be replaced. This usually happens when something has been spilt on the keyboard causing it to type random characters or the characters directly above or below them.
Seeing as the keyboard is a laptop keyboard you can use a wireles/wired keyboard or you can use the on-screen keyboard if you can't get the keyboard to work.
Go to Control panel. Select Regional and Language Options In the Regional options tab, select your country and language settings Click on apply and ok.
You MAY have to reboot for the changes to take effect.
Thanks for using FixYa and please rate this reply if it has helped.
Windows has support for many input-languages, e.g., for keyboards made in France with accented characters,
and for the DVORAK keyboard layout (which is a complete
rearrangement of the letters on the keyboard for maximum
typing-speed).
Go into "Control Panel", and "Regional and Language" and click the "Language" tab, and switch to the "USA Keyboard".
Here you go:
Enter The computer brings the cursor to the beginning of the next line. This key can also be pressed
to open a program after you have HILIGHTED* it. It will execute a command.
Shift ▲ Hold the shift key down and press the letter key you want to make a CAPITAL letter.
This key is also used to type the charters at the
top of some keys. Eg: Shift + 1 = ! or Shift + 2 = @
Caps Lock Makes all letters CAPITAL letters. When the Caps Lock key is pushed, a light will
show up on the upper right corner of your keyboard
next to the capital “A”. When caps lock is turned on it remains on until you press the Caps Lock key
again. When you press the Shift key when
Caps Lock is on, a lower case letter will be produced.
Space This key places one space every time it is pressed. (The long, unlabeled key at the
bottom center of your keyboard).
←Backspace Deletes the character to the left of the cursor each time you press it. (If you hold it
down it will continue to delete so be careful).
Delete Deletes the character to the right of the cursor each time you press it.
Home Brings you to the beginning of the line the cursor is on.
End Brings you to the end of the line the cursor is on.
Esc Located in the upper right corner of your keyboard. Cancels an incomplete command;
it will also close an open menu.
← Moves the cursor to the left one space each time it is pushed; does not delete the
character.
↑ Moves the cursor up one line each time it is pushed; does not delete the character.
→ Moves the cursor to the right one space each time it is pushed; does not delete the
character.
↓ Moves the cursor down one line each time it is pushed; does not delete the character.
Insert Deletes the character to the right of the cursor and replaces it with whatever is typed on
the keyboard.
↔Tab Moves the cursor to the tab marks and between columns.
Shift + print screen Prints what is on your computer screen.
Highlight (to select) To make the item stand out. To choose or select it.
? *When an icon is highlighted (left click the mouse button one time while the cursor is pointing at
the icon), the program has been chosen and the name of the icon will change color. When this has
happened, you may press the Enter key to open the program.
? *To highlight a character or characters, move the cursor, using your mouse or the arrow keys, to
the left of the item you wish to select. Press the left mouse button and hold it down while you
move the mouse to the right. Let go of the left mouse button and your item(s) should be
highlighted. Then you can choose what you want to do to the selected item(s) e.g. bold, underline,
delete, italicize, etc.
“Drag and drop” Move the cursor to the item, click the left mouse button and hold it down.
Move the mouse, while holding down the left
mouse button, to the location you want to move the item. Let go of the left
mouse button.
Cursor - The arrow on your screen. The mouse is used to move the cursor.
Let me know if this helped
It appears that the function key is stuck on. try an external keyboard. if the external keyboard has the same problem its an issue with windows but if not you could be looking at a replacement keyboard. hope this helps Peter
