Question about Technics SL-1200MK2 Turntable
Sound problem Don't know if anyone here can help me but. I have a pair of technics 1210 mk2s, and there only playing through the left channel. So the sound output through my amp only comes through my left speakers.
  • kush d Jan 28, 2008
    ill try this thx
  • 515 Answers
You might also have a bad tonearm connection - make sure your headshell is securely in place. Also take a look at the tonearm pins, this is the 4 pins inside the tonearm, where your headshell connects. If any of the pins are pushed in, then you have a faulty tonearm.
The most common issue with sound is the RCA cables, so I would suggest replacing those first before you go to the tonearm, as the tonearms are pretty expensive.
DJPROLAB
Posted on Feb 24, 2008
    President:
  • 4,402 Answers
First thing to do is take the left and put in in the right, do you get sound on the right?
now take the phono cartridge wires and move the left to the right and right to the left does the sound move or stay same place. if they move with or not tells you if the cartridge is bad or phono plugs. if they dont move it's the phono plugs if the does move it's the cart.
Posted on Jan 28, 2008
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
Turntable only playing in one speaker
In my business I work on a lot of turntables. Specifically, Memorex, Anders Nicholson, Innovative Technology and Emerson. 99% of the time when I only have sound coming out of one channel it is due to a broken cartridge. If you look at the tone arm head from underneath you will see a rubber fork that the needle arm sits in. There are usually 2 ceramic cartridges attached to the rubber fork. Those transmit the sounds from the needle. If one of those brakes then that channel will not transmit any sound.
Dec 07, 2011 | Technics SL-1210 Turntable
My technic 1210 is only playing through one channel can you help with telling me how to repair
First disconect the wires to the cartridge. With you amp on, touch each wire one at a time. You should hear a buzz on two of the wires (one one ach channel) and nothing on the other two. If you do hear the buzz on both channels the cartridge has failed or the connection to it is poor. If you are still missing a channel then the problem lies in either what connects the two devices, or the magnetic cartridge pre-amp inside the amp. If you put the good channel phono plug in the other bad channel of the amp and don't hear any sound it is the magnetic cartridge pre-amp that has failed.
Nov 15, 2010 | Panasonic Technics SL-1210MK2 Turntable
I have 2 technic sl1200s and the right table has noise coming out of the speaker when i moved the tonearm. when music plays, it sounds like the treble and volume of the right speaker is weaker help...
If your left technics sounds good, maybe the problem is the cartridge. Try to interchange the cartridges, right table cartridge by the left one, and listen. If now the bad sound comes from the left table, it´s time to get a new cartridge or stylus. If the problem continues there is something else to look for. Hope this will help. Flavio/Brazil.
Sep 17, 2010 | Technics SL-1210 Turntable
The L side channel has gone on my 1210 ive resolderd new leads on but that hasnt workd, does anyone know what else it could be ??
The most obvious cause is the cartridge. However first of all check it's not your amp. Do this by reverseing the leads so the right goes in the left imput etc. If the fault doesn't go to the otherside, then it's the pre-amp for the cartridge that has failed in your amp (generally an IC).
If that's OK, then disconect the wires to the cartridge. If you then touch the end of them with your fingers you should get a buzz on either channel. If you do it's the cartridge, if not then the fault is inside the turntable somewhere.
Apr 03, 2010 | Technics SL-1210 Turntable
Deck fades out when i bring the second deck in (records I mean)
are you running phono pre amps ? are you running pre amps to each deck or one for both decks , if you are running pre amps maybe the power supply is not sufficient to run two decks anymore [ possibly damaged ] but it sounds like a power delivery failure to me . hope this helps
May 24, 2009 | Technics SL-1210 Turntable
Tone arm snapped off
Unfortunately, not an easy fix. You will need to replace the entire tonearm, and this should only be done by a qualified service center.
If you would like to try it yourself, check out this site - http://djprolab.com - their are DO It Yourself repair videos for this model.
NOTE: This is NOT an easy fix, and if you had to ask this type of question, I am going to assume you don't have much knowledge with electronic repair.
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Dec 27, 2008 | Technics SL-1210 Turntable
Technics SUV500 Amplifier
check volume balance between right and left-then change inter connection between sound source and amplifier with new cabel(i prefer gold plated type connectors)(see radio shack).
after that if the problem excit your fault in output transistors or output stereo ic depend on circuit design.
Feb 17, 2008 | Technics SUV500 2-Channel Amplifier
Channels
Could be one of 3 issues:
1) Tonearm
2) RCA Cables
3) Cartridge/Styli
I generally tell people to try different cartridges first. If that doesn't work, then you know it's either your tonearm or your RCA cables. 80% of the time, it's the RCA cables. It's very hard to determine which one it is at this point without opening her up and putting on some new RCA cables to test. If it works, then your good. If not, then you know it's your tonearm, and will need to be replaced.
- DJPROLAB
Feb 13, 2008 | Technics SL-1210 Turntable
Torque Problem
They actually need to be "broken in". The mk5 uses a different pitch board, allowing you to reverse, pitch up and down to 16, and lock and unlock the quartz. The mk5 is more precise, so its also more sensitive. Notice the notches on the turntable shaft behind the tonearm weight. The mk5  is just make to be finer calibrated.....your decks are fine, and more so probably your mk2s as well.
Oh and also, the infinite lubrication used on technics that was developed in the 70s is no match for the formula developed in the late 90s. Slick!!
Sep 30, 2007 | Technics SL-1210M5G Turntable
Technics SL-1200MK2 Turntable Logo
350 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
