Question about Minolta Di151F All-In-One Laser Printer
Error Message on Start up
"Flash ROM Lost" is the message. My minolta Di 151 will not start up because of this error message. What can I do?
  • Minolta Master
  • 6,696 Answers
Avery ld machine try buying one on line and replace the main board achip or up grade
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Dec 26, 2015
4 Suggested Answers
  • 300 Answers
SOURCE: Konica Minolta Di 520
Try resetting the copier first, power on - open the front door remove small cover on the right hand side press reset button - close door. The machine should now boot, but if the fault is still present a service call will be required.
Posted on May 18, 2008
chibibarako
  • 7 Answers
SOURCE: minolta di 151
You're going to have a tough time finding a paper manual, since Minolta was bought out by Konica. However, if you have Adobe or another PDF reader you can get the manual on the Konica-Minolta website: DI151 Fax Manual
Posted on Oct 24, 2008
  • 5 Answers
SOURCE: minolta di 151 has a problem coping properly, need to know why, replaced toner and still has problem, need either manual or what else could be wrong...
If the printing is poor and almost white copy, you need to replace the developer in the image unit, clean all the lens first to be crystal clear.
Posted on Feb 19, 2010
Why is my magicolor 4650en showing service call c025
Konica Minolta Magicolor 4650EN Error Codes
Code
C025
Display
CONTROLLER ROM
Description
Controller ROM error (Configuration information error)
• Lead error of destination setting file is detected during the printer starting.
Remedy
1 Reboot the main body. 2 Check the PRCB connector for proper connection and correct as necessary. 3 If this error message is displayed after update of firmware, conduct the firmware update procedures again. 4 Change PRCB.
Feb 16, 2018 | Office Equipment & Supplies
Error code 42-2
Below the main power switch (Located left rear) now move your down and towards the front about in the middle is vent well check the fan behind that vent. clean/replace worse case the board controlling it is bad.$$$$$$$$$$$$$$$$$$$$$$$$$$$
try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 19, 2014 | Konica Minolta Minolta Di 650 Di 551 Di...
Minolta di 520 MALFUNCTION
after nessage not apear error code,anymore specification?
Jul 17, 2009 | Minolta DiALTA Di520 Laser Printer
Error message: ROM ERROR, what does this mean?
Error :
ROM Error message
Workaround :
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
In attempting to resolve the issue, reflash the system software for that specific model. If system software does not resolve the error, replace the DIMM Assembly. When replacing the DIMM, you may be required to flash the system software toit's latest version.
iR 1600/2000 FG6-9978-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Jun 05, 2009 | Canon imageRUNNER 2000 Copier
Minolta di 151 has a problem coping properly, need to know why, replaced toner and still has problem, need either manual or what else could be wrong...
May 26, 2009 | Minolta Di151 All-In-One Laser Printer
Minolta Di 1610 f not starting
Scanner home position. Check the scanner itself there is a small piece of plastic that actuates the home sensor, check for dust dirt (can air) sensor is loacated under the glass left side rear
Apr 27, 2009 | Office Equipment & Supplies
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Minolta di 151
Oct 24, 2008 | Minolta Di151 All-In-One Laser Printer
Sharp AR-151
Try this sequence
Press: "Clear", "Exposure Select Key", "Clear", "Exposure Select Key", "26", "Start Key", "39", "Start Key"
there IS another subcode besides E7 try holding the stop or start or clear key you will probably see some different #'s
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Minolta Di 151
How to clear a C-0500 error code.SolutionHold down the [Clear/Stop] key while turning on the power.
For the Di151f, hold down the [0] key while turning on the power.
if the code comes back replace the fuser unit. DO not continue to reset the fuser can catch on fire and that will ruin a perfectly good day.
Oct 21, 2006 | Minolta Di151F All-In-One Laser Printer
Minolta Di151F All-In-One Laser Printer Logo
67 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Marvin
Marvin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
