Question about Uniden Cordless Phone
Phone says searching
My additional handset fo rmy ge 5.8 mhz cordless phone keeps saying searching. my main one works fine and the other handset is find, just the one says searching. cna anyone help?
  • Anonymous Mar 18, 2014
    uniden handset #2 was disconnected overnight. when plugged in next day, display read searching, handset out of range and can't get it to work.
  • 65 Answers
The battery may be weak. Or it is too far from the base. Try exchanging the two. take the handset near the base and see if it will link.
Posted on Jan 29, 2008
  • annieoak11 Aug 03, 2011
    phone said searching no extras land lines not working because of it once I unplugged the phone the rest worked
  • app_3rp62147
    app_3rp62147 Jul 25, 2012
    In my case (binatone handsets) i tried replacing the battery, which worked, but then i put the "old" rechargeable batteries back in and it still worked! So just try removing the batteries and putting them back in to "reset" the phone
My D-Link DPH-C160S keep searching some time it show's message VoIP Ready than goes back to searching...... I have connected this IP Phone after 13 days. Is anyone know's solution ?
Posted on Dec 12, 2008
4 Suggested Answers
SOURCE: i have the D1660 series
I had the same problem, I removed the battery from the handset, placed it back then I remounted it on the base. it said welcome and after 2 to 3 mins, it started showing the signal icon on the left top corner of the display. I picked it up from the base, pressed talk button it started working. Good luck try it out, it would work.
Posted on Sep 17, 2011
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
Posted on Oct 09, 2009
michelletrip
SOURCE: I have a Uniden DECT 1480-5c phone (base 5
have this EXACT same problem---could it be my wireless router interfering??
Posted on Sep 26, 2010
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Radio shack 43-113 cordless phone
Re: "compatible extension hand set"
Have you tried Uniden DXI-986-2 900 MHz Cordless Phone with Dual Handsets and Extra Charging Cradle. You would have to disable the base of the main unit of the Uniden and simply use it as a cradle/charger. Additionally, it may be to your advantage to bring along your Radio Shack Hand set when trying/buying the Uniden to see it they will pair up.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 22, 2008 | Radio Shack 433575 Cordless Phone
I have a GE 25922 5.6GHz cordless phone. It has 3 receiver. 1 of the receiver all ways says unavailble and it does not ring or can't call out. Can you help me with phone? Thank you, Sai.
UNAVAILABLE Indicates the handset is out of range. Or an additional handset is in use. Or there has been a base power failure, in which case you must place all handsets on the main base cradle for 20 seconds to re-register.
Jan 07, 2009 | GE 25922 Cordless Phone
Voicemail doesn't work
That is the government FCC ID Number not the model number :>)
FCC ID G9H2 5838AH 5 8GHz SINGLE LINE CORDLESS TELEPHONE HANDSET by...
Tell her to remove the hand set from the base unit. Remove the wall plug and count to 10 and replace it. Replace the handset.
Press the Answerphone button once to turn it on.
There are GE Manuals in the link below.
ge 5 8 ghz cordless phone manual Google Search
Dec 17, 2017 | GE Telephone pr521w
GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Mar 26, 2008 | GE 28112 Trio Cordless Phone
GE Model 27911 DECT 6.0 Additional Cordless Handset not working
I had the same problem. What worked for me, after several unsuccessful registration attempts, was to disconnect the phone handset battery for about 1 min and then reconnect the battery. Run the handset registration procedure again. It registered for me on the first attempt after the battery reinstall. Good luck.
Jan 20, 2008 | GE 28111EE2 Cordless Phone
GE dect 6.0 cordless phone bought at walmart
We had the same problem.
"Our phones worked fine for two weeks but now you can not dial out
and when someone calls us they can't hear we say. The line still works
fine with our old phone1.gif."
To fix the problem, I simply unplugged the base AC plug from the outlet, waited about 15 seconds, and then plugged it back in. Both handsets said searching on the display and then handset names returned to the display as originally programmed. The phones returned to operation as normal.
Devo
Nov 14, 2007 | GE 28111 Cordless Phone
GE 27831 Cordless - Date Time Issue
should be in the main menu thru the handset setup .unlike cell phones that reset automatically . you must go into setup and do it
Dec 23, 2017 | GE 27831 Cordless Phone
2nd handset doesn't work
Hi Rayfatz,
I think your problem might be that the second handset is not registered with the base station. Take the second phone out of it's cradle and place it in the base station (where the first phone is), and leave it there for 20 seconds. Place it back in it's own cradle, and it should start working. Hope this helps! Hal
May 27, 2007 | GE 26938GE1 Cordless Phone
Cordless Handset fails to Link to main corded phone
Here it is, 2008, March and still no answer! LOL! I am having the same problem! It linked fine when I first got it, and now since I can't find the manual I can't get it to link again! Can anyone help? Please
Apr 13, 2007 | GE 27957GE1 Phone
Uniden Cordless Phone Logo
3,373 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
