Question about Projection Televisions
BT Vision remote code for Sanyo TV
Does anyone know the correct TV code to program a BT Vision remote, for a Sanyo TV; model CE28WN4-B?
  • 8617 Answers
SOURCE: We need the 3 digit
The sanyo FXVR is auto programed for only sanyo Tvs. If it no longer works your tv you will need a new remote you can order one online at the following link and they ship really fast they are located in North Carolina. Heres their link
Posted on Jan 19, 2008
  • 1139 Answers
You can order a new remote from the TV manufacture ORION.
Here is a place that has your remote for about $30.00
I hope this helps,
Thank you,
Posted on May 27, 2008
Google "sky handset codes" and you'll get lots of answers. For example, page
Has a huge table of codes for many manufacturers. A quick search for SANYO on this page gives 3 hits.
One for 3 specific products sent in by the public.
One for the earlier series handsets which offers 0159 as the primary Sanyo code and the following to try if this fails
For Rev 4 digibox remotes and later they offer the following selection:
236 073 100 064 174 165 367 039 245 246 572 583 037 132 182 244 191 398 241
I'm guessing that they are in descending order of popularity.
Failing that why not go directly to the Sky web site where they tell you step-by-step how to do it and have a tool that will give you the correct code.
Not knowing the revision of your handset (4, 6 or 8) I can't say what codes to try, but they all list 236 as the first one, just like the first web site I mentioned.
Posted on Dec 06, 2008
  • 67 Answers
SOURCE: need to program remote to Sanyo tv lost book go to this web site follow the directions
Posted on Apr 14, 2009
SOURCE: I have a Mitsubishi VS-45605 projection TV and a
I've got the same tv and...I've still got the manual!;-)
Programming the Remote to control other audio and video products:
  1. Move the slide switch at the top of the remote to select the a/v product you want to control (in this case, DVD).
  2. Press and hold the Power button so that it stays down when you enter the code.
  3. Enter the code for the equipment. Release the Power button
  4. Point the remote at the equipment and press the Power button. If the equipment respondes, you're done. If not, and you have more codes that apply to that equipment, go back the step 2 and try the next number.
If none of the numbers work, I'm afraid you might be out of luck.
Posted on Dec 14, 2009
  • 10 Answers
SOURCE: I purchased a new Sylvania
I called Comcast and they had no clue. But I called Sylvania and their reps were FABULOUS!!! Turns out, the TV makers send the cable companies the frequencies for each TV then the cable companies send them to a 3rd party to get the codes written.
This model of TV is new and there is no code written. The rep suggested that we countinue to check back on the Comcast website regularly to see if the code is posted. She said that the sales reps tend to get the info last.
The Sylvania rep anticipates a new code written soon because this is such a prevelant problem.
Posted on Dec 20, 2009
0 characters
1 Points
I cannot program the Directv remote to the Sanyo flat screen tv. What is the code and is there a specific button I have to pust to program it.
Thanks for your time. My husband tried to fix the problem and we could not use the remote at all. So he gave up. Our 28 year old daughter called DirecTV and was able to fix the problem and even give us better access to other programs. My husband had inadvertently programmed the tv opposite of what it should have been.
Paula Eldred
Dec 28, 2009 | Sanyo Projection Televisions
I want to find a code to program a radio shack remote to a sanyo tv
I own a One-for-All universal remote, and my booklet says the setup code for a Sanyo TV ( without a built-in DVD or VCR) is 0154. I can not guarantee that this number will work with your remote, but it is worth a try.
Jul 05, 2008 | Projection Televisions
Need codes to program my Phillips Universal Remote control for my Sanyo tv
I own a One-for-All universal remote, and my booklet says the setup code for a Sanyo TV ( without a built-in DVD or VCR) is 0154. I can not guarantee this number will work with your remote, but it is worth a try.
Which code for sanyo tv?
the codes for a sanyo TV are depending on the manufacturer of the universal remote. Need the make and model number of your remote in order to supply the codes you require.
Apr 10, 2008 | Projection Televisions
I lost my orignal remote for my sanyo tv. how do i change the imput sourse with out it?
I am sorry but you cannot. maybe you can borrow one from a neighbor or a friend.
Feb 14, 2008 | Projection Televisions
How to program remote control panasonic EUR7722X50
hola tengo una tv sanyo de 16 pgls model 1430MA(C) compre un control ke dice control original sanyo no especifica marca ni nada asi por el stilo me pueden conseguir la solucion para esto
Feb 10, 2008 | Projection Televisions
We need the 3 digit code for a Sanyo FXVR remote to work with a 32" tv, model # DS3224. The remote we have has lost it code and will no longer work with the TV. Please advise
Program 100 under tv mode
Hold down tv mode as you enter (100) then release tv mode button the red light should flash 5 times signaling it accepted the code and you should be good to go
Jan 19, 2008 | Projection Televisions
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Jan 17, 2008 | Projection Televisions
Projection Televisions Logo
104 people viewed this question
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
