Question about Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony WEGA KV-27FS120 ...shows only channels from 1-13 using the Channel + button but displays others when the numbers are entered manually
I have a Sony WEGA KV-27FS120 and i am encountering a strange problem. When i use the remote to surf the channel it only go until channel 13 and if increase the channel by 1 it goes back to 3. Basically it only shows me 1-13 channels if use the increase channel button. However, i can get channels above 14 by pressing the respective numbers. Like if i press buttons 2 and 4 on the remote i am able to see channel 24 and similarly others 3 and 6 will show me channel 36. I am not sure what the problem. I have tried different remotes and it gives me the same problem. Any suggestion on the this problem ?
    Problem Solver:
  • 4 Answers
Doesn't sound like a remote issue as much as an internal programming problem. If you block a channel due to a bad signal on antenna mode, it'll skip it unless you drop the block. The same happens with "autoprogramming" for cable. Bad channels are blocked due to weak signal.
Maybe you should try auto programming through the TV's initial set-up menu? You can get your television to reset to factory settings by
1. turn the tv on
2. hold down the reset button on the remote
3. press the power button on tv (tv will turn off and on)
4. release the reset button.
5. should be in initial set-up.
Posted on Jan 28, 2008
    Problem Solver:
  • 4 Answers
Sounds like it needs to be switched to cable mode. go in to your menu look for something like STD Cable.
How to get into Service Mode on SONY KV-S2942U (1994 vintage)? Have entered this before using -plus & minus buttons- then switch on to get TT on screen. Entering 01 then MENU should bring up Service...
The service manual instructions to get into service mode is by turning the main power switch on the set. Then press the power button of the remote commander twice.
Jan 19, 2018 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My Sony WEGA is no longer displaying the channel number. I think my house sitter changed something by mistake. I've read the manual but come up with nothing.
Yeah, the setting that you are looking for in the menu says channel label. If you open the menu with the remote, you should be able to access that setting.
Jan 18, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Wega sony KV-36FS17
if you use your Sat remote control turn your tv on/off and there is an info button on the remote. press the tv button and then press the info button that should to it.
Oct 19, 2008 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Switching channels
the problem of your tv is the system ic that controls switching from switch... maybe it has a loose connection..
Aug 26, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony tv channel display
You need a Sony remote that has a "display" button on it. Press the display button and it will go away.
Mar 27, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Channel numbers scrolling
the tac switches have gone bad.this happens from age or sometimes from washing the screen of the set and moisture gets on the.. it is not a big job but it does involve soldering skills
Nov 28, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Channel display
if you have the manua for the
universal remote that you are
using it the button that displays
current channel on the tv
or the one that say jump.
flashback or channel return
might be bottom R corner of
the remote or a small button on
either side of the zero button
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV-27FS120
as no sound on certain channels it means no problem in your tv though it is old. the problem is in transmission line from where you get prog. it can be adjudted manually by vol.control if low sound is there at certain channels. you can also reset once.
Sep 26, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
263 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
