Question about Brother MFC-8220 Fax
Imagistics 2500 fax stuck in the "printing" mode. Need to reset.
The above fax and model is stuck in the "printing" mode on the LCD. I tried unpluging the machine, took the printer cartidge nothing helped.
  • 1 more comment
  • jeremykatz Jan 30, 2008
    Identical problem. Brother MFC-8220.
    Started almost on the same day?!?!?
  • Anonymous Feb 14, 2008
    fax coming in is fine. Fax going out is all black. Will not print on the other end.
  • teknique Aug 06, 2008
    my MFC-8220 was printing fine then the paper stopped feeding and the LCD display was stuck saying "Printing". I unplugged it overnight. I tried clearing the memory. I made sure there was no paper jams and it still says "Printing" and does not feed any paper.
Yes that worked!! I unplugged it, and kept the red stop button push in while plugging back in and it cleared it out! THANK YOU!
Posted on Aug 06, 2008
    Problem Solver:
  • 8 Answers
Try cleaning your scan glass,which is the strip of glass under the operator panel, if that doesn't do it you probably need a new scanner, call your local oce imagsitics office
Posted on Feb 15, 2008
  • udu dudu Feb 15, 2008
    on the machine that is locked up, unplug it, hold down the stop button, and at the same time plug it back it, this will clear out the memory and hopefully take care of the problem....
Mattdasse, your last solution worked like a charm. thanks!
Posted on May 22, 2009
How do i retreive and receive faxes? My machine has recieved material in memory, yet when i try to print them, the alarm rings after first page and display reads "CHECK PAGE SIZE, press OK" It will re
If you are able to print normally from this model, despite the 'stuck' faxes, then it could be that you have been sent a document that is not the same size as that in your tray. Try cutting A4, if that is what you have, down to 'legal' and see if will move on to next page. If this works, cut some more and print job till finished.
If the above makes no difference, you may have to do a memory reset to clear a corrupt fax record. Caution! this would clear all faxes queued in your machine.
Dec 16, 2014 | Canon PIXMA MX340 Inkjet Multifunction...
Imagistics SX 2100. When you change the drum what
Open the door where the toner cartridge is, and push the clear key and look at the display where it will say reset no press 1 yes press 2. That should do it.
Jan 25, 2010 | Pitney Bowes Office Equipment & Supplies
I have an error that indicates paper jam, open-- imagistics 2500
Check the paper trays sensor,and describe detailated the your problem and please tell me the fax machine models for more help and information.
Sep 17, 2009 | Office Equipment & Supplies
Imagistics 2500 fax machine bought used - no book - how do I delete name/phone number of prior owner
press menu*2864 in quick succesion, should take you to test mode, enter 01 and then when that is done, enter 99 to exit test mode
Jul 30, 2009 | Brother MFC-8220 Fax
Faxing problem Imagistics 2500
You're correct, it's the scanner. Finding out what exactly is wrong with it is a little more difficult. First check the easy thing, scan a sample paper 4 times, each time pushing it against a different one of the four corners, and see if the line goes away or changes when you change the location of the paper on the scanner. If that doesn't work, take off the glass plate and clean it and everything under it, then try again. If none of that helps, download the latest drivers.
Please rate, thanks!
Mar 13, 2009 | SMC Accessories Chembook 2500: Port...
Imagistics 2500
With that model I believe you have to leave the toner door open and press start
Oct 24, 2008 | Brother MFC-8220 Fax
Imagistic 2500 Fax problem.
On top of the toner cartridge there may be a blue slider for cleaning the charge wire.
If not, you have a bad toner cartridge (drum cleaning blade)
Sep 16, 2008 | Brother MFC-8220 Fax
Need help to connect my dell laptop to imagistics 2500 printer please
it is possible to set this multi-function fax/copy/printer for printing from your laptop. There is an available GDI driver from the manufacturer's website (http://www.oceusa.com) for Windows Vista 64 (exe file). Other than that it should install like any other printer.
Jul 01, 2008 | Computers & Internet
Says Printing & Online Stuck
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
May 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Pitney Bowes Fax Function Question
I have a 9920 manual,could be the same.Try the following but if you get different displays don't change anything.Press function,should read FUNCTION SELECT , ENTER FUNCTION # .Enter 8, scroll to AUTO REDUCTION.(use COM STAT or HELP keys to scroll)Change to NO.Press stop to return to normal mode.If this procedure is not exactly the same for your model,then just search through the function settings and find AUTO REDUCTION and set to no.
Mar 05, 2008 | Office Equipment & Supplies
Brother MFC-8220 Fax Logo
990 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
