Question about Brother P-Touch 1180 Label Printer
Pt-110 problem I have an older pt-110 that I haven't used for years. I just installed new batteries and a new cartridge. After loading the words and pressing "print", the machine makes noise as if it were working but no tape is feeding. The cartridge is loaded correctly and there are no obstructions to the tape feed. Any advice??? Thanks, Nick
  • 1 more comment
  • Aimee Lou Feb 25, 2008
    Yes, I have the same problem. It makes a noise like it's trying to print, but the tape doesn't feed through. I switched batteries and tape. It's been a few months since I used it, but never had this problem before. I don't want to buy a new machine...I'm quite fond of this bean-shaped one.
  • Anonymous Apr 09, 2008
    Same here. If you remove the cover you can force the pich roller onto the tape using a paper clip and then it works.
  • Anonymous May 26, 2008
    Yeah, exact same problem with the PT-110. I used the paper clip trick and it did work.
    New Friend:
I opened mine up and found that the plastic part which engages the roller is broken i haven't found any parts available so I guess its junk now.
Posted on Feb 22, 2013
I have the same problem. There is a little arm attached to the base of the pinch roller. It's broken on mine causing the problem. Attempted to epoxy the part back together, did not work, part is too small where broken. Don't know if there is a replacement part. New P-Touch was $39.00 at Staples so I'll probably just buy a new one. You have to be pretty mechanically inclined to get the thing apart anyhow.
Posted on Sep 28, 2008
Turn on and word Garmin appears, then it says loading maps then it shuts down.
It sounds like you have a battery that is going bad. The StreetPilot is one of the older Gamins, and have been known to need new batteries after a few years of use. I would advise upgrading to a newer GPS.
Apr 25, 2016 | Garmin StreetPilot C550 GPS
Have inserted new batteries and new cartridge but not able to print
Sounds silly, but are the batteries good and are they correctly installed. Check the pictogram in the battery case and make sure that the batteries polarity complies. Also check that the cartridge is securely fitted and the tape feed is correct.
Jan 17, 2011 | Brother P-touch PT-80 Label Printer
I have a HP 8259 printer and it indicates the yellow print cartridge needs to be replaced even when i install a new cartridge. It will not let me print in color or black/grayscale. I have had the printer...
Older printers can do funny things. It is probable that the little copper contacts on the ink cartridge are not making good contact with the printer which is giving bad information to the computer that the ink cartridge is empty. A two year old printer may have some corrosion on the printer's contacts. Remove the ink cartridge and use a soft pencil eraser to clean the printer's contacts.
Oct 10, 2010 | Office Equipment & Supplies
Need procedure to remove and replace the battery in a 2006 PT Cruiser
  1. Make sure ignition switch is in OFF position and all accessories are OFF.
  2. Open hood.
  3. Remove the air cleaner housing.
  4. Disconnect and isolate the battery negative cable then the positive cable.
  5. Loosen bolt (4) and retainer (1) that holds the battery down to the tray.
  6. Lift battery out of battery tray and remove from vehicle.
  7. Remove thermal guard (if equipped) from battery.
CAUTION: Vehicles equipped with the turbocharged engine use a unique battery hold down. If the replacement battery is not identical, in size to the original, it may be necessary to use non-corrosive spacers on top of the hold down retainer to properly secure the battery in the battery tray.
When replacing battery, the thermal guard MUST be transferred to the new battery (if equipped).
  1. Install battery in vehicle making sure that the thermal guard (if equipped) is present and battery is properly positioned on battery tray.
  2. Install battery hold down hardware (1), (2), (3) and (4) making sure that it is properly positioned on battery. Torque clamp to 12.5 N.m (110 in. lbs.) .
  3. Install battery cables on battery posts. Install battery positive cable first.
  4. Torque clamp nuts to 12.5 N.m (110 in. lbs.) .
  5. Install air cleaner housing.
  6. Close hood.
  7. Verify proper vehicle operation.
Jul 15, 2010 | 2006 Chrysler PT Cruiser
Problems with Panasonic PT-53TW53 replaced the STK392-110 with STK392-180's and the six resisters initially the tv worked fine but now and then i lose convergence then it works fine is this a heat problem...
It could be either a bad connection or a bad new chip--why did you go to 180 chip? The best replacement for the 110 chip this set used is a 150 chip. Keep in mind whatever chip you use they will only last 5-8 years---the problem is not the chip but the heat sink compound grease dries out from heat and whatever chip is in there is going to fail.
If you need further advice consult me--I have fixed hundreds of these sets--replacing with the original STK-392-110 you should get 5-8 years. If you got a new chip that is flakey you are going to have to replace both again to see if it is your problem
Let me know if you need help.
If this helped you, rate this solution as I do this here for FREE.
Nov 24, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Go to:
Select Vista (or Vista 64-bit if you are using the 64-bit version) and download the appropriate drivers from there. These drivers should give you access to all of the necessary maintenance options including resetting ink levels (tell the driver you are installing new cartridges, remove and reinstall the existing cartridges to make it do the reset).
Test page coming out green indicates a problem with the ink cartridges since it should be using the black cart for most of the page.
Mar 26, 2009 | HP DeskJet 3320 InkJet Printer
Convergence for Panasonic 47"
Yes it is that set uses the same IC STK392-110 You can get the new ICs at this link and they will provide free installation instructions with pictures as well as free on line tech support instant messaging while you do the repair. heres the link.
Apr 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
I bought a arabic-English Dictionary NModel BAS-1875 two years ago. last week the arabic words become unclear in the just see black dots for the arabic letters while the english letters are still clear.
Feb 28, 2008 | Office Equipment & Supplies
Convergence chips 110 installed but unsuccessful
check the resisters or send the board in to
if you find bad resisters chances are you blew the ic too
Feb 26, 2008 | Panasonic PT-47WXC43 47" Rear Projection...
Brother P-Touch 1180 Label Printer Logo
822 people viewed this question
James Cagle
James Cagle
Jim Keysor
