Question about iLO DVD Recorder DVDR05
Dvd tray won't open ILO DVDHD04
Does anybody know if there's any way to fix these trays? I've read the 05 has a little emergency slot to use to get the tray to open but the 04 does not have this.
  • Brenda Price May 11, 2008
    I have one that won't open either. I've only used it about 4 times.
    Problem Solver:
  • 7 Answers
Most times it is dust causing problems. Carefully take the unit apart and clean all moving parts related to the tray including the belt, drive wheel Tray slides and motor wheel with Iso Pro obtainable at your local electronics shop. Be careful of touching electronic parts and the head. Do not clean the head slides, they are greased and meant to be. If this fails it could be a slipping belt or weak eject motor. Do not power it up with the lens exposed as this could damage your eyes. The cause of the Jam is that the head mount does not go fully down when the eject is pressed, this locks the tray. It requires a initial greater force to start eject as it has to release the head mount and make it drop all the way to its rest position to release the tray. This is not happening and is a common problem. To take apart, the front tray plate slides off to the top and the face plate clips out after the panels, top and bottom are removed, In some cases only the bottom needs removing to enable the face plate removal without damage. Do not use excessive force when removing or you will break it. Hope this helps
Posted on Sep 08, 2008
Http://www.fixya.com/support/t208832-lite_lvc_9016g_dvd_drawer_not_open maybe this is similar to yours and will work. it did for me.
Posted on May 22, 2008
6ya staff
SOURCE:
Dvd door won t open
Remove the unit and open it up to remove disk and examine the tray drive.
Jun 19, 2017 | Curtis Audio Players & Recorders
DVD ' s tray won't open when pres OPEN, DVD is inside
There are little gears to open the tray with a little rubber belt that drives it you should be able to open door and pull on tray to get disk out if not unplug it take top off push tray out Cheapper to replace player than to fix but little flap should pull down grab tray and pull
Feb 21, 2013 | RCA DRC247N DVD Player
Wont read discs
follow this steps, and use the common sense.God bless you
If the player skips, make sure that the DVD disc is not dirty or scratched..Use the cleaner disk buy it from R. Shack.
If the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
Sep 19, 2012 | Panasonic DMR-EZ37VK DVD Recorder / VCR...
Someone inserted Tray 2 in the slot for Tray 1. it is stuck in one little spot when we pull and we don't want to break anything. We removed the little screw and white wheel that makes the two sides...
I tried to replicate your situation but couldn't get the Tray 2 inserted all the way in Tray 1 slot of the Lexmark Pro905 printer. Tray 2 just won't fit perfectly in Tray 1 slot since the design is slightly different from the other. I presume your Tray 2 is all the way inside Tray 1 slot and that means something got snagged in the slot. I would suggest you to contact Lexmark technical support for additional assistance. Forcing it out might result to an even greater damage to the printer.
May 17, 2011 | Lexmark Platinum Pro905 multifunction...
PC s/n = 0029975695: The tray will not eject. When
The usual problem with disc drives is a little belt that drives the loading tray. It stretches with age and slips, so the motor turns but the belt doesn't. If you want to take the time to try finding one, the belt is replaceable.
On the other hand, new DVD/CD burners are only around $30, so it's usually not worth trying to repair the drive. It's faster and easier to put in a new one.
Hope this helps. Thanks for using Fixya!
Mar 01, 2010 | Gateway (5502134) CD-RW/DVD-ROM (Combo)...
Philips DVD 723 . the tray is not opening. blocked message comes.
There will be a slotted hole on the underside slide a screw driver across this will manually activate the tray dogleg and will part open the tray for you.
Dec 05, 2009 | Philips DVDR3380/05 DVD Recorder
DVD Player tray Door Continues to Open
I had this problem and it turned out to be the gears on the door drive. There are two gears, one that engages the rack on the tray and one that has a slot that drives the clamping action to hold the DVD. These two gears were misaligned by one tooth. This prevented the gear with the slot from turning freely after the door was closed.
To fix it I had to take out the tray assembly, disasemble it, and reassemble it with the gears properly aligned. You need to remove the top and back of the case. Then take out two screws at the rear of the tray assembly and three screws on the circuit board attached to the tray assembly. Unplug the connections to that board. Slide out the tray assembly. Now you can pop the top off of the tray assembly by pulling out two tabs and sliding the top toward the rear. Now you can get to the gears to adjust them. The slotted gear should be able to turn freely for about 1/4 turn when the tray is closed. Make sure the pin on the clamping part is in the slot when you reassemble it.
Jan 06, 2009 | Panasonic DVD-S35S DVD Player
DVD player tray will not open
Maybe this will help someone look in the right direction. A friend gave me a KISS DP-1000 with the same problem: The TV showed the 'Eject' graphic, and nothing happened. There is no little hole that you can poke a paperclip in, like on a PC. I opened the player, and still could not find anything. Then I googled the model of the actual tray mechanism (DSL-710A). The datasheet said that it did have an 'emergency eject' machanism, operated by a Philips screw at the bottom of the tray. There are no holes at the bottom of the DP-1000, only a dimple that dead-ends. I broke through the bottom of the dimple with a small, flat, screwdriver, then enlarged the hole. I felt around with a medium Philips and it fitted into something. I twisted gently, and the tray popped out. Why KISS covered the 'emergency eject' screw is anybody's guess, but I am not buying any of their products.
Feb 25, 2008 | Televison & Video
Tray doesnt open
I just had the same problem with mine and after a while it said baddisc than it would let me open it, just a suggestion I don't know if you have tried this or not...
Oct 27, 2007 | iLO DVD Recorder DVDR05
iLO DVD Recorder DVDR05 Logo
297 people viewed this question
Top iLO Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
