Question about Intel D945GCL Motherboard
Pc slow hi my system is slow when i try to on computer its opens slowly what can i do and when i try to shut down the computer its slowly shutdown the computer what can i
  • brajesh4255 May 11, 2010
    please help me
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 28 Answers
There are a number of issues might be affecting your PC's performance, some are dangerous while others not that serious.
Learn why is your PC running slow and how to speed it up easily from: http://www.whyismypcsoslow.net/
Posted on Sep 02, 2012
  • alimoradi Mar 04, 2013
    hi; i solve my problem. it had bad sector . i repair it by chkdsk
    Sergeant:
  • 226 Answers
Press windows key + pause break key. tell me what are the specs of your pc.
Posted on Jan 28, 2008
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
Why is my computer so slow and especially for games?
press ctrl+delete 1 select task monitor to see what prosses are running
or press ctrl+delete 2 and shut down + force shutdown.
Feb 01, 2013 | Acer Aspire One PC Notebook
Laptop will not shutdown
Remove the battery and unplug it from the wall. Try holding down the power button for about 8 seconds it should shut down. Just a suggestion! When you shut down your laptop make sure that your shutting down properly at the start button select shut down. If all else fails and this does not work.
You may want to have the power button checked out or the board. Or clean files out and start up programs add-ware or spy-ware may be preventing you from shutting down as well. This is also a common issue that causes very slow shutdowns on any computer system packed up junk having to close out. John
May 11, 2012 | Dell Latitude E5500 Laptop
Slow computer shutdown
Tip #1: Cut down of the programs and processes running in the background.--When you start your computer many unnecessary processes are loaded. You can eliminate this by managing your msconfig.
Here is how:
1. Open your Start menu.
2. Click Run
3. In the command screen type "msconfig.exe"
4. In the system configuration utility,click either service or startup tab.
5. Uncheck all programs that your are no longer want to run in the background.
6. Click OK
Tip #2: Defrag your Computer--The faster your computer can find files the quicker it can shutdown. A very slow computer shutdown can be the result of your hard drive trying to search for disorganized and fragmented files that it needs for shutdown . Organize your hard drive by performing a defragmentation.
Here is how:
1. Open the Start Menu
2. Click on My Computer
3. Right Click your C: drive or your hard drive image.
4. Scroll down to the Properties and Click
5. In the Properties Menus, Open the Tools menu.
6. Choose Defragment Now.
7. In the Disk Deframenter menu. Click on Defragment
Tip #3: Clean your Registry- Usually slow computer shutdown often occurs due to a corrupted registry. You should perform a registry clean, use RegInOut to fix this issue instantly.
Dec 18, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Slow shutdown
Try to check-up control panel of your PC, I know your PC configured for automatic windows application update. also try to full scan(present anti-virus software) your PC system maybe same spyware, worms and virus inside on the operating system (OS) and other software desktop.
Please see screen shot picture below.
Oct 18, 2011 | Dell Inspiron 531s Desktop Computer
My computer has been frequently shut down
When Windows does not shutdown properly it can leave behind a lot of files that will cause your system to run slowly. I recommend you download and install CCleaner (http://www.ccleaner.com/) run this program once install. It will clean up these files and help with system performance, you can also run the Registry cleaner in it as well, this will find and fix registry issues. The reboot your computer after these steps are done and seen how it performs. I install this application on all computer I support and run it daily, the users could not be any happier with the performance. Another step I recommend you do after this is Defrag the drive, with help with performance as well.
Jan 19, 2010 | Computers & Internet
I have Dell inspiron 1420, but my laptop starts & shutdown very slowely
hmm that means there are lot of service is running in your computer...try this for starts-
1)open run command
2)type msconfig in run.
3) uncheck all unnecessary program at startup tab then restart system.
now for shutdown pc
try this
1) open run command
2)type regedit
3) search waitforkill registry using ctrl f.
4) increse value of waitforkill like 200 to 20000.
Mar 29, 2009 | IBM ThinkPad T30 2366 Notebook
Command Prompt shut down my computer
had the same problem and found an exact solution here...
might as well try it on yours
http://www.techykid.com/virus/auto-shutdown-virus.html
thanks
Apr 08, 2008 | Computers & Internet
Cpu
Your computer shuts down slowly because there are a lot of services that run in the background that have to close before the computer shuts down.
Another reason that it will be slow is because of some programs that stay in residence have to close too.
Running defrag and scandisk will sometimes speed up startup and shutdown.
Dec 26, 2007 | Computers & Internet
Computer Shuts down
Well your processor may be damaged..
dont worry may be it is not damaged so what do you do is that open the cover of your computer.... Then start it and keep the cover opened making sure that you can see the processor fan running...
See that if the processor fan is running...
then with the help of a torch see that may be the fan is being restricted or it is moving slowly.
this slowness of the fan heats up the processor and makes it shut down you PC
if the is running slowly take out the fan using the user guide of the processor and then lubricate it with motor oil.
it IT Does not work then there is a problem with your processor so please check by placeing another supportive processor and check it!
Dec 13, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Intel D945GCL Motherboard Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
