Question about HP 610 Color Copier
HP 610 message Phone off Hook
I am getting an error message Phone Off Hook and i am not sure how to clear the message. i have a HP 610
Hang up the phone
Posted on Mar 27, 2008
Unable to download from marketplace in lumia 610. I tried setting the date and time even cleared history and cache still error d000f001 is showing whenever i download. plz help
The store is no longer supported for WP7 handsets like the Lumia 610. There is no solution apart from getting another phone.
https://answers.microsoft.com/en-us/mobiledevices/forum/mdlumia-mdapps-mdlumia600/about-nokia-lumia-610-error-code-d000f001/0e8988c7-7f5e-48d0-9c28-9156d4f1bdac?auth=1
Jan 28, 2018 | The Computers & Internet
Phone off hook message
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver is off the hook (the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message. Checking the phone line The most common reason for this message is when a dial-up modem is accessing the Internet on the same phone line. Just as two phone calls cannot come in at the same time, two devices cannot use the phone line at the same time. If a broadband modem (such as DSL or ISDN) is on the same phone line and the message appears all the time, please contact your Internet provider for assistance. Even if a dial tone is present when listening to the phone line, the HP product may detect the broadband data connection at the higher line frequencies. Broadband modems must have a line filter installed to work correctly. Contact the telephone company for assistance. Please follow the directions below to verify functionality.
  1. Verify that the phone cable going into the HP fax product from the wall jack is a two-conductor cable type, not four-conductor. A two-conductor cable, like the one that ships with the HP product, has two copper leads in the connector. The connectors are usually clear, making it possible to see how many copper leads are inside the cable. Replace a four-conductor cable with a two-conductor cable.
  2. Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. If the message persists, see the "Problem still exists" section below.
  3. Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Continue with the steps below if a dial tone is present.
  4. Plug the phone cable back into the HP product and hang up any phones with a lifted handset.
  5. Disconnect, one at a time, other phones and devices using the same phone line. Check the HP product display after disconnecting each phone or device. If the message clears after disconnecting a phone or device from the line, the problem is with that phone or device.
  6. If the message still exists after unplugging all other phones or devices, see the "Problem still exists" section below.
Problem still exists If the problem still exists after performing the steps above, the line interface unit (LIU), the part that the phone line plugs into, may be defective or the HP product may need to be serviced.
Jun 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
Off the hook
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver isoff the hook(the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
Lets try the following,
if issue still exists try the followign
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Apr 22, 2014 | HP OfficeJet 4215 All-In-One InkJet...
Our HP OfficeJet 7310 is giving the error message, "Phone off-hook". We have tried restarting it.
I had this same problem. I changed the phone cord to a 2 conductor DSL phone cord. Problem solved. Try it. It should work for you.
Jan 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Scanner failure message
dont worry
just install it in ur pc and just setup all setting to its default
Mar 18, 2009 | HP 610 Color Copier
My printer will not receive a fax saying "phone off hook". There is no phone on the HP2410, and the phone is on the hook.
  7. Problem still exists
  8. If the problem still exists after performing the steps above, the line interface unit (LIU), the part that the phone line plugs into, may be defective or the HP product may need to be serviced.
Jan 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
Phone off hook error message
perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpu01832&cc=us&lc=en&dlc=en
May 22, 2008 | HP Officejet 6310 All-In-One InkJet...
Will not fax
It is a default message when you are calling from the same phone as your fax machine.
If yourAll-In-One is sharing a phone line with your telephone, modem, or another device, and if any of the other devices is using the line, you will see the "Phone off hook" message on the All-In-One front panel. You can still print, copy, and scan with the All-In-One when you see this message, but you cannot send or receive faxes. To clear the message, check each device to make sure that it is no longer using the line.
Apr 13, 2008 | HP PSC 2210 All-In-One InkJet Printer
Scanner error
sounds like a bad power supply or hvt, have it checked out, can be dangerous
Dec 02, 2007 | HP 610 Color Copier
HP 610 Color Copier Logo
110 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
