Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Need new power brush
I need a whole new power brush - not just the roller - for my Kenmore Whispertone 116. Maybe it's also called "Progressive". I can't find this part anywhere so far. Help!
  • 3 more comments
  • mryan161 Jan 29, 2008
    Thanks, but I tried that, and it came up with zero. Mary
    Kenmore Model 116. 53913300
    Class P-F7
  • mryan161 Jan 30, 2008
    I checked it out. That part is just the roller. I need the entire power head -- the whole unit. Thanks, Mary
    Thank you for your time. Mary
    Good idea, I appreciate your help! Mary
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Hi let me try to find that part for you. I assume color will not be an issue. will get back to you as soon as I can
Posted on Feb 20, 2008
    President:
  • 1,673 Answers
Get the number off the power head, it should be on the bottom, then go to Sears.com, click on the parts link, put in the complete model number, a parts list will come up and you can order your part.
Posted on Jan 29, 2008
  • 2 more comments
  • Lauren Junge
    Lauren Junge Jan 29, 2008
    What is the model number of the power head, also the model of the vacuum, need the complete number.
  • Lauren Junge
    Part # is 8192535 agi. unit, sells for 37.79.
    You can call their 1-800 #, or online at:
    http://www.searspartsdirect.com/partsdir...
  • Lauren Junge
    Lauren Junge Jan 30, 2008
    Not sure that you can buy the whole power head, it would be a sales item, have you talked to them at a Sears store? From that link I gave you, there is a contact at the upper right corner, try sending them an email.
  • Lauren Junge
    Hi, had another thought, Panasonic would have a similar powerhead that I am sure would work, you might check with a dealer to find out.
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
When vacuuming the belt stops turning
Your belt is probably stretched, replace it. Also check to be sure nothing is lodged in the brushes
Sep 03, 2012 | Panasonic Kenmore Canister Vacuum Hose 116...
Carpet roller brush will not turn
You probably need a new belt. You can get kenmore belts here:
Kenmore Belts
Jan 02, 2010 | Vacuums
HOW DO YOU CHANGE BELT CANT SEEM TO REMOVE BOTTOM TO GET TO IT KENMORE WISPERTONE 116
The top cover to the light lense pops off at the ends. When you get that cover off then you will see 2 screws that are by the swivel neck. Take those out and then the whole body top cover comes off. That will get you into the roller brush and belt area of this machine.
Dec 11, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Wish to remove bottom ofpowerhead-Kenmore Progressive 11629912990
I have a whispertone vacuum, different model #, but maybe instructions will be the same. Turns out I didn't need a new belt, just clean out the crud and reset overload protector. The instructions in the manual tell you to remove the light cover and bulb first. To do this, press in and lift both sides. Push in and turn bulb counterclockwise to remove. (you need to do this because the next step involves turning the unit over). This takes you to
Step 2. Unscrew the cover screws ( on either side of bulb).
Step 3. Turn unit over. To remove cover, insert screwdriver at cover tabs on both sides and twist to release tabs.
Step. 4 Turn unit right side up. Press handle release pedal and lower the swivel. Tilt cover forward from back until front snaps free.
Step 5. Carefully insert and twist screwdriver at each brush support to free brush from base.
Step 6. Remove worn belt.
Step 7. Slide brush supports off to check and clean brush support areas.
To replace belt: slide washers and brush supports onto brush assembly.
Install new belt over motor drive, then over brush sprocket.
Snap brush supports into place on base. Be sure brush supports are not upside down.
Line up front of cover and base. Rest cover on front edge of base. Tilt cover to back. Press cover firmly until side tabs snap into place. Replace cover screws, light bulb and light cover.
Mar 11, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
String caught in end of rug brush
This pdf file should help you - there are instructions in it for removal of the roller.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0412323.pdf
Rate if this helps :)
Feb 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Aug 08, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore whisper tome model # 116
If this uses a cogged belt, it should not fall off unless it is the wrong one. Give me the whole model #, then I can look and see what you have. The number of the power head is needed.
May 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
298 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
