Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Ps3 how do i connect my lynksys wireless router to my ps3
    Sergeant:
  • 226 Answers
I have a lynksys router. It will work with our mac, but if i try to get online with my pc, neiter will connect or if one is connected, it will disconnect. can i fix this
I see that you are having issues with your network connection, I believe that you are trying to connect wireless on both systems.
* Check your Linksys for settings that limit the routers wireless connection, most wireless routers have an option on how many computers can connect wireless to the router, a wireless signal does not chose what OS to allow for a wireless connection.
* get in your Linksys Routers Setting page from IE or Firefox using your Default gateway IP from there on you can check your Routers settings, user name depends if your internet service provider changed the Routers user name and password but for a Linksys try admin / password or admin / admin for the User name and Password field.
Hope this helps you thanks and have a good day.
Mar 30, 2011 | Cisco Lynksys Dual Band Wireless N Gigabit...
How do i set nat settings for lynksys Wireless-G Broadband Router for xbox 360
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Aug 10, 2010 | Linksys Wireless-G Broadband Router
Have lynksys wireless router but is unsecure -
You can enable WEP on your router to make your wireless network secure.
To access the screen of the router, type the ip address of the router in the address bar of Internet explorer or Firefox. By default the ip address of the router is 192.168.1.1. If this doesn't work, go to the command prompt (Start -> run -> type cmd). Type ipconfig. Copy the default gateway.
It will prompt you for a user name and password. By default leave the user name blank and then type admin in the password field.
Once you are in the Linksys screen, go to the Wireless tab -> Wireless security.
For the security mode, select WEP.
WEP encryption: 64bits 10 hex digits.
On the Passphrase field, type a wireless password of your choice, then click Generate.
It will give you a key. You will need to copy the wireless network key because you will need to enter this key on your PS3 and laptop. Take note that this is also case sensitive.
Once you click save settings, it will disconnect all your wireless computers.
You will need to manually enter the wireless network key on all your wireless devices. Without the network key, other computers will not be able to connect to your network.
I hope this helps.
Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated.
Feb 16, 2010 | Linksys Wireless-G Broadband Router
Connect my Lynksys WRT54G2 Router with my Belkin (F5D6231-4)
You can connect 2 routers to each other. But the IP address will be different for both the routers .
It will be better to keep different names for the wireless network.
If you keep the same name, then it doesn't mean that the signal strength will be good. Because both the routers will broadcast their own signals.
If you want to increase the signal strength then you can purchase a wireless range expander.
Click Here for more info about the networking
Nov 04, 2009 | D-Link Wireless Starter Combination Kit...
Lynksis Wireless Router does not stay connected to the Internet.
I suggest checking the documentation of your linksys router in the linksys site. Get the manual and that would tell you how to set it up. Regarding the router being broken, it is possible. Are you wired or wireless to the router?
Jul 22, 2009 | Linksys Wireless-G WRTP54G Router
Cant obtain ip adress
Have you set up your lynksys to allow wireless QoS? If not go to your lynksys broadband wireless software. If you don't know how enter 192.168.1.1 into your explorer bar, log in with lynksys, default is top line blank password 'admin', go to Applications and Gaming tab and enable Wireless QoS, you'll also see all of the places to establish and open ports for specific applications.
May 09, 2009 | Linksys WRT160N Wireless Router
Lynksys Connectivity Problem
occassionally, the wireless router needs to be turned off and on. The are some issues with regards to the stabitlity of these entry level wireless routers. What I do is put a timer at the outlet to reset it every morning. cheers!
Oct 16, 2008 | Linksys Wireless-G WRT54G Router
Connecting wireless router to laptop computer
Try changing the channel on the router. It would be better to isolate the problem first by trying to connect to other wireless networks on your laptop or having someone's laptop connect to your home wireless network.
Sep 03, 2008 | Linksys WRT54GX2 Wireless-G Broadband...
Shared wireless connection between laptop and PS3
Hi philly - If this fixes your problem please rate as fixed. PLEASE wait til your fixed. Are you runnimg your pc wired? Check to make sure that your IP connection is set to obtain ip automatically and obtain DNS server automatically. What's your operating system please/ Thanks.
Jeff
May 17, 2008 | Linksys Wireless-G WRT54G Router
Please confirm that this model is indeed a wirlles Modem/ ADSL Router and not just a Wireless Router without the ADSL/ Modem capability??
Apr 20, 2008 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
132 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
