Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Hoover floor mate wet/dry - brushes do not spin
The rotating brushes do not spin
    Sergeant:
  • 201 Answers
Hey there bankshots, if you look at the bottom of the head of the vacuum, you should be able to see the brushes. Their are some screws to remove to gain access to the inside of the bottom panel. When opened, you should be able to see the entire spinning brush assembly. On one side, there is an area which has no brushes and may contain the remnents of your belt which most likely is the problem. These belts are often replaced and not the sign of any thing to worry about. Replacements can be found at registered repair facilities. Alternately, a professional will do it for you for a modest charge. Also your warranty may cover this if your machine is less than a year old, or you purchased the extra protection from the seller. Good Luck!
Posted on Jan 28, 2008
I have a hoover floor mate hard floor cleaner and the brushes won't spin
Hi, it's Jeremy from Crucial Vacuum.
In the link below you will find the user manual for your Hoover Floor Mate vacuum:
http://hoover.com/file/597/
Here are a few repair tips to make fixing your vacuum easy. Your Hoover brush-roll is connected to the motor by two different sized geared belts. Over time, the belt's gears wear down and stretch out losing the grooves and tension that turn the roller. When this happens you will simply have to attach a new set of belts. Another reason why your brush is not spinning could be that there is debris stuck in the roller and/or bearings. You can either use a can of compressed air to remove the debris or simply remove it with your hand.
You can purchase direct your replacement Hoover Floor Mate parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/index/?manufacturer=37&q=floor+mate
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 06, 2014 | Vacuums
My floor mate won't dispense liquid onto the floor
make sure the solution tank is on properly this link is for the manual
http://hoover.com/file/683/
Aug 04, 2012 | Hoover H3010 Upright Wet/Dry Vacuum
Brushes don't spin
Hello :
try this please : switch the carpet/bare floor dial back & forth 5 times, ending on carpet. Tilt the handle back as if to vacuum upright & lay the vacuum on its side so it is resting on the side opposite the carpet/bare floor dial. Turn the vacuum on.
or try this also if the above suggestion didn't work :
Maybe the belt is broke. You will have to replace the belt before the roller can spin. You must have run over something in the carpeting like string or whatever to have it break. Happens all the time. Get several replacement belts to keep as spares while you're at it as nothing is worse then having to vacuum and no spare belts.
please rate !
May 07, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
My rotating brushes stopped rotating and my steam vac smells hot...is it a belt?
the hot smell makes me thing the motor is stuck
do not attempt to use it unless you can rotate the motor by hand. If the motor spins freely then it could be a belt. check if the belt turns
Feb 02, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Brushes on hoover deluxe steam vac cvarpet cleaner are not rotating. Took out the brush assy and drive spins slowly but with little torque. Cannot seem to open the bottom to see if belt or direct...
(1) Assure the brush shut off lever on the hood is not set to the off position.
(2) Is there still a square pin standing up from the one drive brush? It should be 1/4 square, and about two inches tall. That pin is the drive from the transmission to the brushes.
There are no belts. The transmission is air and gear drive mechanism.
Oct 02, 2009 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Loud noise, smell smoke, brushes turn slower than before, stoped using
yes there are replacement parts for your hoover call any athourized hoover dealer and give them your model # usualy the motors are more expensive than the hole machine
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Cleaning Solution
The solution is called "floor to floor" sold in a white 48oz bottle
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Jan 18, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floor mate 500
If you mean the footswitch that shifts from wet to dry, trun the machine over with the brush assembly removed. There is a black rectangular oush button on the left side. This is the wet/dry switch. Make sure it is in contact with the white post to the left of it . It is the indicator that moves when you step on it. Push the button all the way in and out until it latches. After that it should work OK. Hope yhis helps.
Kirk Thompson
San Juan, PR
Aug 27, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
296 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
