Question about Neovo F-417 17" LCD Monitor
Auto adjustment. An annoying problem I can't seem to solve. Once in a while my monitor feels it is time for an automatic 'auto adjustment'. Sometimes for more then an hour, sometimes for several days. That blue screen in the middle of my screen is terrible annoying. After a while it goes automaticly away. Only to reappear a few days, weeks or months later. Thanks for helping.
After getting some clues from some posts on here I found an easy solution.
Take the back off the monitor- 4screws.
Unscrew the 3 fixing screws holding the little circuit board with the control panel buttons. Unplug the two long multiwire circuit board plugs. The menu buttons and on/off switch will now be inoperable. The monitor stills turns on from the monitor main switch on the right backside of the screen. The screen resolution can still be controlled from Windows XP and your graphics card.
No more unwanted appearances of auto-adjust menu ! I have not yet tested this monitors problem long term but so far its just fine.
Posted on Dec 21, 2011
Try this one:
the is not the same problem. But the cause is exactly the same
Posted on Feb 10, 2008
Screen size and resolution keeps changing while I work.
some tv devices are set by default to auto adjusting, look in tv's setup and adjust the resolution manually.
Feb 23, 2013 | Toshiba Computers & Internet
My viewsonic monitor automatically adjusts its contrast and brightmess settings without my involement and it is very annoying, to use the monitor with auto adjust display all the time on the screen of my...
in the menu of the LCD there should be an option for an "Ambient Light Sensor" or Energy Smart Plus Disable the sensor or set Energy setting to NORMAL (I had the same issue with my new Dell LCD and a sunny but partly cloudy day)
Jan 10, 2011 | Computers & Internet
My monitor keeps saying auto adjustment in progress
Hello Friend,
This is automatically adjusting your Screen.Horizontal/vertical manual manual adjustment and Focus adjustment can Solve the Problem.Turn off auto feature. I hope your Problem can be Solved by going to this link for Detailed Instruction of your Monitor...
Thanks for Contacting FixYa...Keep Using..
May 11, 2010 | HP w2207 Monitor
Auto Adjust keeps popping up
Is this a computer moniter or a tuner/tv
Aug 02, 2009 | BenQ FP71G 17" LCD Monitor
Auto adjust doesnt work
try to push the menu button for 5sec, maybe it will be solve the problem..
Jul 11, 2009 | Samsung SyncMaster 913N 19" LCD Monitor
HPl1906 lcd auto off and on blinks
Check the power regulator AS431A
Mar 21, 2009 | HP L1906 19" LCD Monitor
Convergence problem
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Display problem
the adjustment box for colour, brightness and contrast stays fixed on the screen. i tried pressing the exit button.... after a few times it disappears only to reappear within a few minutes. also the auto adjustment option, for which we are supposed to manually press the i button, keeps auto adjusting the screen whenever it feels like it. the box appears right in middle of the screen and is a real nuisance as it blocks out the main portion.
Jun 28, 2008 | BenQ FP547 - 15" LCD Monitor
"Processing Auto Configuration" keeps showing up on my screen.
It solved by fixing 1024X786 pixel solution.if it not possible by fixing it..
Then look over the VGA driver is correctly support or not
if not then you have to update the VGA (Display) by drivers
Dec 24, 2007 | Gateway FPD1530 15" Flat Panel LCD Monitor
Neovo F-417 17" LCD Monitor Logo
676 people viewed this question
Top Neovo Computers & Internet Experts
Level 1 Expert
Dimitar Todorov
Are you a Neovo Computer and Internet Expert? Answer questions, earn points and help others
