Compaq Presario R3000 Notebook Logo
Posted on Dec 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replaced power socket on motherboard. Now it will not boot with the recovery disk. Screen is blank. Did static destroy the board? How do I know. Computer worked fine before repair.
Scott P
Level 3:
  • Master 1,087 Answers
  • Posted on Dec 29, 2009
Scott P
Master
Level 3:
Answers
1087
Questions
Helped
262565
Points
2538
Who done the repair? Thats not the easiest job to do considering what you have to break down to get to that cornor of the board. If a shop done it you should be able to take it back and you already know the answer to your question about static. If the job was done sloppy and the sodder got to a part of the power grid on the board there would be your issue. If the sodder got where it wasnt supposed to be your looking at a dead shorted board. I charge about a hundred to do that job although the part is only $2-$3 dollars the time it takes to do it right is about 2 to 3 hours. If you done the job yourself this will be an expensive lesson of why you buy a $5 static band when breaking down a laptop or any static sensitive device. Honestly although the damage may be done and your feeling frisky BUY the wristband tear it down again look at your sodder job you may get lucky......Best of luck hope you get it going
My computer screen is blank black it's an acer
u need to check power and then remove ram chip from mother board and clean the coper points with white pencil rubber. if not then u have to enter recovery disk if u created or boot with booteble disk and select f8 and select boot with last known good configuaration.
I have zotac 512mb graphic card. whenever i attach this on my motherboard and start the computer than my computer will start but the sceen will become blank
either it\'s not supported by the OS,ie windows, or not configured properly in the bios....press (F2 for set up) @ the start,this will take you into the bios,then use the arrow keys to move around,their are instructions on the bottom/side of screen, find the boot up graphics sequence & change it to boot ( PCI-E first, then ON BOARD/AGP second) if it goes ups, & you an on board socket, then go back & swop them round & take the card out, & use the on board socket until you can boot up & instal the drivers for the card......
another way is to download the drivers, or get the disk that came with the card.
then switch it on, then when it starts, press & hold the power button, until it powers off, then switch it back on again, & you should be given the choice to boot up in safe mode, log in with safe mode, & install the drivers.
then do the bios thing i said before.
3answers
Inspirion E1405 boots to blank screen. Trying to
If it's a BIOS password, you need to remove the battery from the motherboard to reset it. If it's a Windows password, you need this CD to reset it: http://www.howtogeek.com/howto/windows-vista/change-your-forgotten-windows-password-with-the-linux-system-rescue-cd/
Does not boot. displays intel desktop board in blue screen
Blue error message comes when there is any issue with memory.
First Refix your RAM memory.
Then boot your computer with recovery disk.
For that you have to set first boot device as your cd or dvd rom .
When you power up the computer press F1 or F2 or "del" key then you see bios setup screen.
Then go to boot option and set first boot device as cd or dvd.
Then put bootable disk in computer then it boot with it.
Then follow the procedure on screen.
choose "R" option for enter in "Recovery Console"
Then type in prompt "chkdsk /r"
then it fix error on harddisk then then restart computer then if still same issue then you have to repair your windows with recovery disk.
Let me know if you need more assistance.
Thanks.
Blank screen on start up
Try removing all cards with the exception of the video. Remove all memory leaving (1) to boot from.
Disconnect power and reset the processor.
If you have a boot disk or copy of XP on disk, try to boot from the CD or DVD.
If the unit boots at all the problem may be the HD.
If not try downloading the BIOS update for your chipset.
Remove all extra drive, like secondary CD or DVD drives, Floppy or Zip drives.
You may have burnt the processor but I don’t think so.
Power supply is OK or you would not power up. Their are 3 or 4 supply voltages from supply, +- 12 volts, +- 5 volts and +-3.3 volts.
You may have a secondary 12 volt 4-pin plug but that is for on board video.
Try a boot disk and flash your BIOS, if you can.
Hope this helps.
Blank screen
To reset the CMOS first unplug the power cord from the back of the computer. Now open up the left side-panel of your computer (the power button is what I consider to be the front of the computer). Now touch the metal chassis or something metal to discharge any static electricity. Afterward take a look at your motherboard (the main board sitting inside the computer). Look for a battery similar to the one shown in this picture. Once you find it, take it out (might take a little force). Leave it out for about 24 hours. Afterward stick it back in (remember, discharge static electricity before sticking your hands in the case) the motherboard and close the case by re-attaching the side-panel. Now plug the power back in and try to boot the computer.
Let me know how it turns out or if I need to explain further on any one point.
1helpful
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Installed new motherboard for Dell Inspiron 1000- blank screen
The F5 and F8 functions are normally used by Windows to shoose between C:\, Safe Mode and normal boot.
Setup is a function of the BIOS manufacturer and it could be any key but is normally F1 or F2 as the screen says in your case.
I don't know what your specific problem is but it is a new board and sometimes they don't survive the installation due to improper handling.
The almost universal use of CMOS technology makes some of the chips very sensitive to static discharge even with countermeasures in place to protect them.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
