Question about GE Spacemaker WSLP1100D Top Load Washer
"Lo" error code
I have 18 of these terrible machines. The are 1 1/2 years old. So far I have had 2 of them give me an error code of "Lo" This code is not in the manuel. The Sears repair guys have no clue what it is. On says its the lid switch, and another says its a circut board problem.
Anyone have an idea of what could be going wrong?
  • 5 Answers
The lid switch could be bad.
Posted on Jun 19, 2008
    New Friend:
    A rookie expert who has answered 20 questions on their first day.
  • 82 Answers
It is the assemely checker... which is the lid switch........was working on a GE erro code...Lo...i would say it would be the same for other brands in the space saver catagory,,,part number for this repair is ...WH12X10102,,,,your welcome,,,,B&B applance here.
Posted on Oct 02, 2013
When ever the lo lite comes on my machine it means the led is open
Posted on Feb 24, 2008
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from
Oct 19, 2015 | Washing Machines
Im getting a "LO" error
The LO error code means the LID OPEN
Here is what the techicians service manual say to check
LO Door failed to unlock Door lock monitor switch does not indicate to the machine control board that the solenoid in the door lock mechanism retracted and unlock the door. 1.Check for debris inside inside the door lock mechanism, which may be jamming the lock solenoid. 2.check wire connections in harness leading from machine control board to door lock mechanism.
3.Check the door lock monitor switch for welded contacts.
4.Replace responsible component.
Jul 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
El led del papel se queda parpadeando y no imprime es como si tubiera algo atorado
Units built before June 18, 2008
Units with a S/N having a Year Built and Week Built code earlier than "08-25" are reset using the following procedure:
1. Open the media compartment and remove any media.
2. Press the Feed button and hold it approximately ten seconds until the Power, Communications and Error indicators turn off and stay off.
3. After the three indicators turn off, reload the media and close the media compartment cover.
4. Wait at least ten more seconds and press the Power button. The Printer will restart and normal operation can resume.
Units built after June 18, 2008
Units with a S/N having a Year Built and Week Built code of "08-25" or later are reset using the following procedure:
1. Press and hold the power button for 5 seconds and then release. The printer will power down.
2. Re-start the Printer as usual. Any pending data in the printer will have been deleted and must be re-sent.
Dec 16, 2010 | Zebra MZ 320 Thermal Printer
The machine wont empty water gives a code of 03 I have cleaned the drain filter and check the drain hose still wont drain water unit is 1 1/2 years old
03 is drain error, as you know. The machine is sensing that the water isnt draining enough in 5 minutes...Unless there is an electronic problem the main reasons for the error code is because the drain hose is blocked, or the pump has something preventing it from turning, like a coin jammed in the impeller, or the pump motor itself needs to be replaced....These pump motors tend to get detritis in behind the impeller shaft seal and this often causes the pump to fail.....Good luck....Nomess
Jun 16, 2010 | LG WM2233H Front Load Stacked Washer /...
Year lo 1 time month lo 2 times weekly 4 times rojulo 6 times vachedi enti ?
year lo 1 time(12 months: 1+2=3 odd)
month lo 2 times(1 week and 3 week these are odd numbers)
week lo 4 times(1 Sunday, 3 Tuesday, 5 Thursday, 7 sat day)
day lo 6 times( 1o clock, 3,5,7,9,11)
Jun 07, 2010 | Nokia Lands Phones
BRand new installation of 1 year old machine we
I am a novice at front loaders but it sounds like it needs new suspension parts, namely springs, sounds like the machine had a hard life before you got it. since its used anyways it cant hurt to take the back off and see and study how it works and how the drums suspension works. you can try to find the springs at an appliance store. Im not sure if you can get springs directly from LG. LG's are a pretty good name brand, probably worth fixing..
good luck!
Dec 28, 2009 | LG WM-2277HW Front Load Washer
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
GE Spacemaker WSLP1100D Top Load Washer Logo
1,505 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
