Question about Belling 644 Electric Kitchen Range
Belling format main fan not working, element getting hot nut no fan?
    President:
  • 1,462 Answers
Probably the fan jammed with crud but could be a faulty fan motor. remove the back panel inside the oven and the fan is exposed. try giving it a flick to see if it rotates freely. if no joy then the fan motor needs replacing. faily cheap part and not too hard to fit
Posted on Jul 04, 2008
Tip
Common faults with Belling 317 Range
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BELLING fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BELLING oven thermostat
4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 17, 2010 | Belling 317 Electric Kitchen Range
How do I change the oven element on a belling format 800 oven
1, If your Belling fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.To gain access to the BELLING element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
Jan 03, 2010 | Belling XOU492 Electric Double Oven
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Tip
Common faults with Belling 335 Range
on Jan 17, 2010 | Belling 335 Electric Kitchen Range
Tip
Common faults with Belling DB3 Dual Fuel Range
on Jan 17, 2010 | Belling DB3 Dual Fuel (Electric and Gas)...
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Dec 22, 2006 | Belling XOU270 / XOU271 Electric Single...
Tip
Common faults with Belling DB90 Range
on Jan 17, 2010 | Belling DB90 Electric Kitchen Range
Tip
Common faults with Belling FarmHouse 932
on Jan 17, 2010 | Belling FarmHouse 932 Dual Fuel (Electric...
Tip
Common faults Belling XOU252
on Jan 17, 2010 | Belling XOU252 Electric Single Oven
Tip
Common faults on belling cookers
on Jan 17, 2010 | Belling XOU592 / XOU593 Electric Double...
Belling 644 Electric Kitchen Range Logo
234 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
