Ipod washed
Also after leaving it in the rice for 24 hours you will want to connect the iPod to your computer. It should come right on, but if it does not try resetting it. Below I have posted a step by step on resetting an iPod just in case you need the information. If it still will not turn on at all, leave it connected for at least four hours. Then attempt to reset it again. If none of these steps bring you to a resolution, you have a hardware issue and will need to either service it or replace it. I do hope this helps though. Please let me know how it turns out.
Learning how to reset or restart your iPod.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
My nanoipod was washed should I try to charge it?
ipod get wet when riding my motorcycle down to daytona in the rain. played the entire ride down until it died. when i tried to charge it wouldn't work.
