Question about Zebra Stripe S400 Label Printer
Not printing on Label
The Zebra is on, full of the ink, full of labels, but when we print, the label comes out with nothing on it, Any solutions?
The solution when I had this problem turned out to be that the temperature setting was 0. It needs to be around 15-20.
Posted on Aug 28, 2009
    President:
  • 4,402 Answers
Bad print head.
Posted on Jan 28, 2008
Printer prints faint labels
Hi. Thanks for your question
Print fainting could be caused by number of reasons. First think to check is ink roll. Replacing with new one would get this out of the way. If it still faints next thing I would do is once you opened the cover try and clean the print head and any visible rollers underneath the labels. Print heads can be cleaned with any alcohol solution. Best would be some kind of electronics cleaning solution. next thing to check would be labels themselves. It happened to me that labels where simply not very well finished and ink would not stick to them. Try roll of labels from other box you may have. If this all failed and your printer still faints labels that it never used to it could be the worse. Your print head may need replacing although this is very unusual for them to fail in this way.
I hope this helped you. Please don't hesitate to come back and ask more questions if this is needed. I've worked with thermal printers for 7 years now and I am sure we can find some solution to your problem.
Thanks for using FixYa
Dec 08, 2010 | Zebra Z6M Plus Thermal Label Printer
My Zebra Z4M Plus printer is printing, but some part of the label is missing. The printing is good, and starting from a certain point, nothing is printed. There is a straight line (approximately 2cm from...
if is line across all the label, need printhead replacement, but first clian the printhead and the rollar, then check if the length and the with is the correct from the driver, last solution, resect the printer to factory defult.
Nov 04, 2010 | Zebra Z4Mplus Label Printer
My Zebra s600 - the ink takeup reel is not working.. works a little when first powering on, but the ink roll then stops moving.. When I print a label, the label comes out, but the ink roll does not...
turn the printer off, press FEED, PAUSE and CANCEL at the same time, still pressing, turn the printer on, wait untill the ligths coming on, and then relese the bottuns, it gona print the sensor profile, then press the last button 4 times untill the 3 ligtns flases, it mins that the printer save the data, then turn off and on again.
Oct 13, 2010 | Zebra Stripe S600 Thermal Label Printer
Changed rolls of labels on Zebra GX 420T and now nothing prints
Were the new labels thermal paper? Thermal printers need specially made paper to work right.
May 28, 2010 | Zebra LP 2844 Thermal Printer
Ink smearing
This is a compatible ribbon/label combination as Zebra says. The only thing you can try is to turn up the darkness setting. The 5586 ribbon you are using requires a fairly high darkness setting ~ maybe around 25. If this still doesn't work then the best solution would be to use a Zebra card printer that prints right on the plastic card. These are made for exactly what you are trying to do. If you don't want to buy the printer then we can print them for you when you need them. I can give you my email if you want us to help.
Jun 23, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I channged the ribbon and the printer will not print tried several thing but it look like everything goes ok but there is nothing printed on the labels
Check that ribbon is installed correctly. Zebra ribbon only has ink on one side. ink side must be facing label. Use a label to check which side ink is on stick label onto ribbon and peel off.
Jun 14, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Dec 12, 2007 | Zebra Z Series Z6M Thermal Label Printer
Zebra S4M Thermal Lable Printer Not Printing Correctly.
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
Oct 26, 2007 | Zebra S4M Thermal Label Printer
Zebra Stripe S400 Label Printer Logo
316 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
