0F00 errors are hard disk drive errors. You will need to replace the hard drive. If under warranty, call Dell Tech support. If not, then you can buy a new drive from places like Newegg.com
Hard drives fail, it is a fact of life. Likely nothing that you could have done to prevent it. Instructions on how to replace the drive are here:
http://support.dell.com/support/edocs/sy...
You can buy a replacement drive here:
http://www.newegg.com/Product/ProductLis...
Most often, HDD failures are caused by de-lamination of the media surface (The magnetic coating on the platins that actually hold the data is flaking off, similiar to rust bumps under the paint on a car) and the debris causes additional damage causing more and more data loss. Only resolution is to replace the drive.
Also, if you don't mind, please rate the advise.
Hello, the screen just went black while I was looking at a web site and I could not re boot it. Tried disconecting power cord and battery but just keep getting a black screen. I ran the diagnostic test which came up with several errors; 0f00:1378B, 0f00:065D, 0f00: 075D, Efoo:0232, etc...I don't know what these mean.
Thank you, do you know what would have caused a hard drive error? And is this something I would be able to replace myself?
of00:137B, 0f00:065D, 0f00:075D, EF00:0232, etc..
Post the diagnostic error information, that will give us something to work with on this issue.
What were the errors?
