Question about Whirlpool SF367 Gas Kitchen Range
Whirlpool oven I have a Whirlpool electric oven and the display is saying F1E2, is this something I can fix myself?
  • 4 more comments
  • Jbob Jan 30, 2008
    Yes I tried unplugging it for 30 seconds or more and plugging it back in. The stove works fine, but the F1E2 code only comes on when I hit the "Bake" button.
  • Jbob Jan 30, 2008
    The Broil function doesn't work either. The model number is RF365PXMQ0
  • Jbob Jan 30, 2008
    Thank you all, I will try this and let you know.
  • Jbob Mar 21, 2008
    I tried using the eraser method, but it didnt seem to get me anywhere. Should I clean all of the connections, of just the ones on the ECC?
  • Jbob Mar 21, 2008
    ok where exactly do I need to check the ohms?
  • robert samples May 11, 2010
    yes first disconnect the power for 30 sec and see if it clears
    President:
  • 1,314 Answers
If you get down to the control panel first try plug and unplugging all the connectors as resistance can cause this in the connectors next take the Mylar ribbon off the control and clean it softly with a pencil eraser as the touch pad malfunction can cause now if you have an ohm meter you can ohm the oven probe it should be 1200 ohms at 70 degrees room tempture if all this fails to fix it then replace the controls bd ive seen too many techs too quick to replace a 200.00 control board just because the eoc spouts out an error code
Posted on Jan 30, 2008
  • 5,911 Answers
F1E2 indicates a failure with the Electronic Range Control (ERC). After you disconnect power for 30 sec and re-apply power. Watch the ERC for at least one minute. If the error code re-appears, Whirlpool recommends replacing the ERC. The board costs between $105 and $160 depending on your model number. This IS something that can be accomplished by the average do-it-yourselfer. It's a simple matter of securing the power and removing the back cover of the console. You will need to write down all wire connections (a digital camera also comes in handy for this) before removing the control board. Usually 2 to 4 screws hold the ERC in place. If this sounds like something you wish to pursue, provide me with your model number (located along the oven door or lower drawer opening) and I can determine a part number for you. If you need further guidance on how to repair, I can do that for you as well. I hope this information is helpful.
PS Once you add the inflated price of the control board and labor costs, a repair like this can run close to $300 for an appliance repairman to do it for you (Just something to think about...)
Posted on Jan 29, 2008
  • Jeff Rockwell
    Jeff Rockwell Jan 30, 2008
    You could still have a problem with the Electronic Range Control. The BAKE and BROIL functions are controlled by separate circuits on a common circuit card. There's a good chance that you have a bad relay that controls your BAKE function. These circuit boards are considered "non-serviceable" and usually require replacing. You can try and see if you can isolate the failure down to a failed component if you like. I don't know how savvy you are with electronics. You may be able to find the component(s) you need at an electronics repair shop. There should be a tech sheet located inside the console, or on the back of the range that you can use for troubleshooting. If you can provide me a model number I can determine how much a new ERC might cost you. It may not be that expensive. Let me know...
  • Jeff Rockwell
    Hmmm...now your BROIL function quit too? I agree with tech17. Unplug the range and remove the back cover of the console. Carefully, remove all your connectors (ONE AT A TIME) and clean the contacts with some emery paper or rubber pencil eraser, first. You could easily have some oxidation that may be keeping it form working properly. If it still does not work after a thorough cleaning...the only recommendation I have left is to replace the ERC.
Code F1E2 on whirlpool electric range mean
This is not a good code and usually means the electronic control will need replacing. Try disconnecting the power for a couple minutes and if the error comes back, the control is bad and will need replacing.
Sep 27, 2014 | Whirlpool RBS275PD Electric Single Oven
F1e2 error code
F1E2 error code usually refers to something with the control board. I do not have info before me, but believe the board has to be replaced.
Package info somewhere inside your stove will give you the explanation of that error code.
It does not hurt to unplug the stove for fifteen minutes/turn it on again and see what the error code is, if any.
Oct 19, 2013 | Whirlpool SF367 Gas Kitchen Range
E2 F6 ??? What the? Oven came with house, no manual.
Your oven temperature sensor has failed(e-2) as well as your electronic control board(f-6). The oven temp sensor, electronic control board and the touchpad must be replaced . Approximate cost of parts is $500.00. Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 12, 2009 | Whirlpool RBD305PD Electric Double Oven
Error F1E2 Whirlpool Super Cap Gas Range 465, oven crazy!
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Nov 22, 2008 | Whirlpool GS460 Gas Kitchen Range
Error code F1E2
The code F1E2 refers to a watchdog circuit in the ERC (Electronic Control Card). This can only be corrected by replacement.
Dec 29, 2007 | KitchenAid KESC300 Electric Kitchen Range
Whirlpool Gas Oven
The F1, E2 codes mean you have UL ac-dc errors. This means you need to replace the control.
Dec 21, 2007 | Whirlpool SF367 Gas Kitchen Range
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Whirlpool SF367 Gas Kitchen Range Logo
701 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
