Question about Samsung RS2630SH Side by Side Refrigerator
Temp light flashing on freezer
I have a problem with the temperature light that just started flashing on my freezer and all the items inside are starting to thaw. I just bought it last month, who do I contact to repair it in Woodbridge, VA? It should be under warranty. I don't know what could be wrong with it
  • 3 more comments
  • alicia6266 Jan 28, 2008
    Does anyone know the contact information for who I can contact to get someone in here for a warranty repair? I've had technicians from Sears home repair come in before, but I don't know if they do warranty for Samsung products. Is there a repair department I can call to get a tech out? I would appreciate any suggestions you can offer.
    Thank you so much for your help. I will give them a call first thing in the morning then. Hopefully the stuff in the freezer will last that long if I can convince the kids not to open it too much. Thanks again, Allie
  • Anonymous Feb 03, 2008
    i have had my refigerator for 3 years and have the same trouble but the light flashes on the fridge and everything is going off rapidly and the fridge is not cold at all. havent a clue what to do or why its doing this any ideas anyone?
  • kairia Feb 06, 2008
    my fridge freezers light started flashing (the number 3) and its not getting cold,the freezer is now leaking
    help!
  • Gary Davd
    Gary Davd May 11, 2010
    If it is new YEs by all means let the warrty servuicer compy. come look at it we dont want to do anything that would Void your Warrty
  • 770 Answers
Sears Should the unit is made by whirlpool
Posted on Jan 28, 2008
Why would the freezer and fridge temperature indicators flash after a few hours of the unit being switched on?
Hi, some fridge freezers the indicators flash as they have not got to the right temperature yet. Also some freezers have indicators that will start flashing to let you know that the door has been open to long and the freezer temp has risen.
Jan 20, 2016 | Refrigerators
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
The temperature for the fridge and freezer will not stay constant. Why?
I would think first of the defrost termination thermostat malfunctioning.
This would vary the defrost time since it regulates the defrost time by temperature.
This is the most common failure in fridges next to start relays.
It is a two wire item in the freezer section which is clipped onto a tube. It senses
line temperature and turns off the defrost element when that temp is reached.
Should be located in the freezer section behind the back panel. Model and serial
number should be inside the refrigerator compartment, Part should be available
at an appliance parts store. Hope this helps.
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Temperature swing specification in a chest freezer.
It depends on the control that your freezer utilizes.
If your temp control dial has the numbers 0-9 or 1-9, then you have whats commonly known as a coil temp sensor.
Unlike an air temp contol that measure the air temp inside the freezer and comes on and off with a 3-5° swing, the coil temp sensor runs a little bit different.
With a coil temp control or sensor, the temp control has a capillary tube and bulb that is inserted into the coil either at on of the ends down a guidetube or just into the center of the radiator type fins. This temp control measures the temperature of the coil, and not the temperature of the air inside the freezer. When the unit runs, the coils typically gets 20° colder than the air temp. And when the control satisfies (shuts off), it will not call for cooling again until the sensing bulb has reached the cut-in point which is typically well above design box temp.
So, to quickly answer your question, yes it is possible to have a 25° temp swing and not have anything really wrong with the unit. That is how its been designed to operate and that is how it will operate. Your only option (although not recommended) is to replace the coil temp sensor with and air temp control. That will give you more consistent temps.
Also, when taking temp of a freezer with a coil temp sensor, be sure to temp the product in the freezer and not the air temperature.
Jan 01, 2010 | Frigidaire 14.8 Cu. Ft. Chest Freezer -...
Hotpoint Whirlpool upright freezer. The lights all work but the temperature is slowly dropping - now only -7 C and the freezer is silent. Before this the temp lights kept flashing and vibrating (quite...
Problem has sorted itself out. We removed and gave away quite a lot of food from the freezer and cleared away some ice that had accumulated on the temperature sensor. When we checked this morning the temperature had returned to -24 C so we don't need to go in search of a new freezer today, thank goodness!
Dec 27, 2009 | Whirlpool Freezers
Side by side kitchenaid freezer temperature indicator.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 30, 2009 | KitchenAid KBLP36FMS Bottom Freezer...
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Mar 21, 2009 | Samsung RS2534 Side by Side Refrigerator
Servis fridge freezer
It may be that the temperature of the unit is not yet up to temp.The flashing light will indicate this.Warning the user the unit is not ready,or up to safe temp.. Let the unit run to catch up,since you just started it.
Nov 30, 2007 | Frost Freezer WCWO F15WA FREE - POCKET...
Samsung RS2630SH Side by Side Refrigerator Logo
806 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
