Question about Sony KDF-E55A20 55 in. LCD Television
6 red light blinks-possible thermal fuse prob.
What is the thermal fuse part # and how do you replace it
  • 43 Answers
The thermal fuse is located under the optical block. However the optical block needs to be removed to replace it. So unless you are very familiar with the disassembly of this tv I suggest you have a Sony ASC to do the repair work for you. You don't want to take a chance of damaging the optical block.
Posted on Jan 30, 2008
  • tieshastaffi Aug 16, 2011
    im not that handed im a lady that really dont no much about wires and stuff but i was wondering and some 1 please walk me threw this install or email me the instructions on how to replace it!
Sony tv model kds-60a2000
Please count the amount of blinks before it pauses. The number of blinks will say if the door isnt latched all of the way or if the thermal fuse has popped above the lamp area. Hope its a 6 blink as that is the thermal fuse which is easy to bypass or replace.
Sep 20, 2016 | Sony Televison & Video
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
I'm having the same problem with my tv (wega sony kdf e60a20) just like a few other people here, with the sensor cutoff fuse, how do you replace this item?
If you mean the thermal fuse, the set should have a red blink code of 5 blinks. The thermal fuse is way inside on the frame of the lamp housing but can be tested with rear cover removed.
If you have one bad the red blinking light will have to display some code.
Dec 22, 2012 | Televison & Video
How to replace thermal fuse
Same question again? You want instructions for replacing the thermal fuse that protects the Lamp?
If that fuse is gone the red light will blink a specific sequence like 5 blinks 5 blinks
Mar 21, 2012 | Sony KDF-E60A20 60 in. LCD HDTV
6 blinking red lights
You still have your guessed problem. 6 blinks means Low B+ error (power supply). This can be caused by an open thermal fuse, loading by another circuit board, or the power supply itself.
Apr 13, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony Wega KDFE55A20 screen and sound going out, red blinking lights, but comes back on...then repeats. Replaced the bulb about 8 months ago and seemed to solve the problem. But it is occuring way too often...
p# 19100239 6 blinks indicates fuse. Do not plug set into switched outlet. besure set is allowed to cool down before ac power is ever removed. Thermal fuse is on the optical block under the lamp housing. do goole search for part availability and source.
Apr 25, 2009 | Sony KDF-E55A20 55 in. LCD Television
Replacing Thermal Fuse in Sony Grand Wega KDF-E55A20
The PROPER way to replace the thermal fuse is to remove the optical block first. There are at least two recessed screws holding the block in place. BE VERY CAREFUL removing the block as it is very easy to tear/rip wires when doing so. I cannot emphasize enough NOT TO JUST THROW THE NEW THERMAL FUSE INSIDE THE CABINET!!!! The thermal fuse is a safety device mounted near the lamp to prevent overheating. Those that choose to just let the fuse "sit out in the open air" are risking greater failures and the possibility of fire.
May 27, 2008 | Sony Grand WEGA KDF55E2000 55" Projection...
You need the location of the part that's stamped on the board near where it was soldered in. And you need a soldering tool to resolder the new part in and cut the excess wire with cutters so you're not to short out the circuit.
C-Dog
Feb 10, 2008 | Sony BRAVIA KDL-40V3000 Television
the g1 board is your issue. 6 blinks means there is no or low b+ coming from the g1 board.
Oct 08, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KDF-E55A20 55 in. LCD Television Logo
435 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
