Delonghi "the incredible heat machine" started smoking
i've just started to use the Delonghi "the incredible heat machine" for about 2 weeks ago. Just yesterday, the heater started smoking (just a little) thru the top vent. i immedietly pulled the plug, waited a few hours to try again and it still smokes a little. is this still safe to use as i dont want this to cause a fire in my apartment of course. what can i do to repair it?
the heater has been in storage for a long time and i wiped it down prior to using it.
pls. advise
thanks!
  • 1 more comment
  • tell_me_more Feb 13, 2008
    I have been using "The Incredible Heat Machine" by Delonghi and I hadn't had any problems until two days ago. I turned it on after having it off for about 8-10hrs and a few minutes later, I heard a little crackle/sizzle, kinda like hot grease. It wasn't loud like a spark and it came from inside the heater, not the socket. It scared me because I know that this is an oil filled heater and I thought maybe the oil got too hot but it had been off all day. Is this heater safe to keep using? It's been pretty cold up here so could this have been the oil getting warmed up after being cold all day? I'm paranoid that I'm gonna burn myself or my room. Feel free to e-mail me at wanjiru21@hotmail.com. Thanks.
  • Anonymous Nov 16, 2008
    it popped loud,then started spraying oil all over room,hot oil
  • fibber2 Jan 18, 2009
    I found this thread because I looking for a solution to a similar problem. I bought mine new in the mid '80's, and did receive and install the recall mandated repair kit (new control panel, cord, etc.). It worked great back then, but it has been in storage for some years now.
    I took it out this Fall, as the price of oil made electric space heater use suddenly affordable. I wiped it down well, but it stinks when hot. Never used it again until today. Again, cleaned it and put in out in the garage to see if it would burn off whatever might be outgassing. An hour later, the garage smells like scorched/burning light oil. Only thing I can imagine was a slight seal leak somewhere, but I don't see anything. I guess it is time for it to become landfill.
Hi Coyote,
I don't know about your specific heater, but, as someone who has a vast electronics background, things that heat tend to give off some fumes. Many electronic componets are LIGHTLY coated with an oil product to provide humidity protection, while the product may sit in a warehouse for years. Typically, such protection, upon being heated, will disperse in the first (maybe) hour of use. but, it could be more, I guess.
BUT, fumes should never be taken lightly. FUMES SHOULD NEVER BE TAKEN LIGHTLY!!!. FUMES MAY KILL YOU!!
How I handle it is...if the fume is noxious, so as to irritate your nose, or eyes, etc. IT IS BAD!!!
Nevertheless, if I were in your boots, I would take the unit outdoors, and let it run on 'HIGH' for about a 1/2 hour, or so. After it cools down, take it indoors and try it again. If it is still fuming, write the manufacturer a "fuming" letter.
Good Luck,
Papou1
Posted on Feb 10, 2008
  • 3 Answers
There was a product recall in the late '80's for the thermostat/heat control of "The Incredible Heat Machine"; there was a common failure with risk of fire. I don't know whether there were actulally any fires. I own one myself, and love it. I checked with Delonghi in the early 90's about getting the repair kit under the recall, but they were quite rude to me, and said that the recall had expired, and that I'd have to purchase it. I didn't (because they were rude!) but have only used it in my workshop while I am in the room. If you can find a local appliance shop that has an old-timer that doesn't believe in the "throw-away" economy, he or she might be able to take a look inside and tell you whether it's a fatal problem. Sometimes a simple arc can be repaired with cleaning and dielectric (insulating) goo.
Good Luck!
Jim
Posted on Mar 02, 2008
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
Delonghi Magnifica Rapid Capucinno Power button not working. Hi all, We have a delonghi coffee maker that stops working few weeks ago. The machine doesn't power up. When you plugin into the outlet...
It's quite likely your unit had a blown thermal fuse caused by a bad thermostat. Test them by disconnecting one end and a meter should show continuity if the part is good. The pro's test them in circuit while the unit is plugged in, power showing across the part means it is bad. REPLACE BOTH PARTS TOGETHER.
Jul 02, 2017 | DeLonghi Esclusivo Magnifica ESAM3300...
De Longhi electric heater, "The Incredible Heat Machine" (2 ft. high, 15 in. long, 6 in. wide), has 2 buttons, 1 for 600 wats, the 2nd for 900, for a total of 1,500 watts. Has worked fine for years. The...
With a new plug and a new outlet it leads me to believe the machine is getting older, dirtier, and drawing more amps than the wires can handle. If disassembling and thoroughly cleaning is doable or in your mind, worth it, that's what I recommend. Otherwise it's in your best interest, being a fire hazard, to replace it.
Jun 25, 2017 | DeLonghi Heating & Cooling
Hi i just bought a 93 mercury sable and i have been driving it for about 3 week. just 2 days ago it started to over heat so i checked the coolant and it was very low, so i add some up to the full line. i...
White smoke is caused by coolant or water coming out the tail pipe. white smoke continues you have an internal coolant leak, i.e., cracked head/blown head gasket.
Sep 15, 2010 | 1993 Mercury Sable
Delonghi coffee machine making an aweful noise,
Hi. Husband asks: When you first turn the machine on at the power point, does it make a motor sound and then stop, or is the awful noise apparent at that time.
If the awful noise starts as soon as you turn it on, then most likely there is a motor problem which will need to be seen by a Service Center.
To locate information about De'Longhi in your country, refer to http://www.delonghi.com/
May 24, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi "The Incredible Heat Machine"
blows the house fuse after being on a few minutes
Feb 13, 2008 | DeLonghi EW0507 Oil Filled Radiator Heater
Delonghi Incredible heat machine can't turn off the timer.
Timer is set by moving the little black switches out over the orange ring. You may need to use a coin--but slide it so that if the orange ring is visible when looking at it dead-on (crouching down, obviously) then it's off at that time and vice-versa.
Jan 13, 2008 | Heating & Cooling
Heating & Cooling Logo
3,323 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
