Insert the disc into the console properly. If the Wii is positioned vertically you should face the label to the right. If you lay the Wii flat, make sure the label is facing up when you insert it.
Check the disc for residue. If you spot something on the disc that could interfere with its operation or potentially get inside the console, you need to clean it. Use a dry cloth and wipe the bottom of the disc from the inside out. Do not rub it in a circular motion. This could scratch the disc.
Read the label. Wii consoles in North America will play game discs made for use in North America only. On the bottom of the label you should see a note that the disc is manufactured for Wii consoles in the United States, Canada, Mexico and Latin America.
Turn the power of the Wii off. Disconnect the AC adapter from the wall outlet and wait a couple of minutes. Plug the adapter back in and turn the console back on. Insert the disc again and see if it works.
The first step is to check the disc. If you are sure this is not a problem with the game disc, then this is usually a problem with either the laser inside of the Wii's drive, or some other issue going on inside of the DVD drive. The following website sells the DVD drive mechanisms and does repairs on the Wii as well. If you have tried cleaning the system already, there's probably a problem with the DVD reader:
drive mechanisms and does repairs on the Wii as well:
The first step is to check the disc. If you are sure this is not a problem with the game disc, then this is usually a problem with either the laser inside of the Wii's drive, or some other issue going on inside of the DVD drive. The following website sells the DVD drive mechanisms and does repairs on the Wii as well:
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide,
that gives step by step information on Dis-Assembling with screenshots,
even a novice can fix the disc eject problem with the help of this DIY
Guide. It also gives information on fixing many Wii Related Problems,
so its a kind of Wii Problems Reference Fix Guide
so its a kind of Wii Problems Reference Fix Guide.
