Question about Hitachi 60SBX78B 60" Rear Projection Television
Hitachi 60sbx78b Won't Turn ON...need advise
I have experience with electronics and circuits, but not tvs. It tries turning on, can hear the speaker amp turn on, then it tries turning on the tubes, but turns off right away. Then red light blinks on power board after it gives up. All the green LED lights come on except the +B 120v. And there is no voltage to the +B on the flyback. Could it just be a regulator out, or could something it be shorting? Are those IC's on the heatsinks next to the green test lights switching transistors or regulators ?
Or maybe somebody could point me in the direction to obtain a cheap schematic or repair manual. Thanks.
  • 1 more comment
  • x_x_5150_x_x Jan 28, 2008
    well, i found a cheap repair manual, waiting to hear back from the place.
    well, i might not need anybody's help. after hours of searching google i found somebody with the exact same problem and got this answer, i will check these 2 components next:
    "yes the most common problem for this is a pico fuse opens it is labeled E994. it is bad most likely because C707 is bad. in some cases the horizontal output will go bad because you have a bad flyback transformer and this also will blow E994, but 90% chance it is C707."
  • elimitator Feb 20, 2008
    Where is C707, E994???
I have a Hitachi 60 UX 54 B....problem am having is: when I turn on the tv it stays on for about a minute, clicks off by itself, have to disconnect from wall wait about 2 to 5 minutes plug back in, if am lucky it stays on but if am not have to repeat the whole process again until it stays on....could the problem be the C707 and pico fuse like mentioned above....even though it is a different model number? Thanks Guys....Becky from Texas
Posted on Jan 28, 2010
    Problem Solver:
  • 3 Answers
I had the same problem. the fix was to replace capacitor C707 and pico fuse E994. After replacing those two parts TV works fine. fcs0998@aol.com GENE
Posted on Aug 16, 2009
    Genius:
  • 1,694 Answers
If cap value is 1000 pf ( 102k ) 2KV, beef it up ! I use Sony part # 1-161-754-00 ....102k 3KV.......Note: sometimes shorted cap
is hiding under dried gob of placement glue............
Make sure pico fuse is correct amperage.......T.
Posted on Jan 29, 2008
  • Hitachi Master
  • 3,459 Answers
You can get the parts from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix the following models (50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B). The kit includes the E994 pico fuse and the C707 capacitor.
Posted on Nov 02, 2008
My tv sometimes will not turn on and and the light start blinking
projection TV`s have many protective circuits in them, they protect your CRT`s from damage, over voltage called x-ray, and many others, you need to have it checked before the damage is more costly your TV is not happy and needs to be checked
Jan 31, 2010 | Hitachi 60SBX78B 60" Rear Projection...
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Cannot turn on TVour TV model is 60SBX78B, Hitachi project TV
If your remotes are out of the room and you try to turn and it still wont come as it should ,then You have a problem with the power switch or the supply, your unit needs to go to the shop . Sorry. DFD
Apr 11, 2009 | Televison & Video
Tv won't turn on.
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Oct 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi Projection Color TV 60SBX78B
Hope this helps,
Oct 03, 2008 | Hitachi 60SBX78B 60" Rear Projection...
60ux58b hitachi
Hope this helps,
Apr 29, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi model #60SBX78B
The green led or lights on the board indicate some of the power supplies are working. The key is do you see any come on and then go out. this would indicate which part of the power supply is failing. also there are fuses in the set that do not look like your standard glass fuse. WARNING television generate lethal voltages that will hurt you. extreme care should be used.
Jan 18, 2008 | Hitachi 50SBX78B 50" Rear Projection...
Hitachi 60"(60sbx78b) Will not power on, fuse still good.
Matt, Hitachi`s have a series of green LED`s and one red LED on the main board, un-plug the tv for 30 seconds and then with the back cover removed plug the set back in and watch the led`s while someone else turns on the set, usually the led`s will temporarily light then one or more will immediately go out and then the rest will slowly go out and the red one will then start blinking, each led is a power supply indicator, 130 volt, 12 volt, 5 volt etcetera, find out which one(s) going out first and get back to me, BMW Rider
Jan 04, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Televison & Video Logo
549 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
