Question about Kensington VideoCAM SVGA Webcam
W98_REQUIRED While trying to install the videocam on my new computer the instillation gets to 100% then says W98_REQUIRED entry not found in the string table. What is that? How can I fix it?
  • Weldon Dube'
    Weldon Dube' May 11, 2010
    This camera has drivers only for Windows 98. That's why I recommend Microsoft or Logitech cameras because they support the latest windows program.
    Soory I couldn't be of more help. Bud
Rcint failure. string table id not found. '46' at line 246
let me tell what will i do if i m at your place.. i will prepare a windows 7 bootable pendrive first.. then i will forcefully shutdown windows.. then i would turn on pc & i will boot from pendrive and perform a clean install .. i will also format whole harddrive so that problem is uprooted.. try this
Nov 29, 2011 | Computers & Internet
Format whole hard drive & Re-install OS. By doing this all problem will be gone. Backup sensitive data before formatting
Nov 29, 2011 | Microsoft Windows XP Professional for PC
I have problem when i start my pc a error message appeared rcint failure string table id not found 42 at line 462
This problem usually occur due to soft booting the machine (reset) and then it could not restart. Usually after the xp logo screen u can only got the parser message: string table not found '42' at line 462. (which is a registery sincronization error (r,sint)). Click the ok button many times and your machine will boot up. Then go to control panel, user accounts, create new account. soft boot your machine again log onto new account and delete all files found in file search with stylexp and tgtsoft in them. Tthen log off and restart and log on as usual user (p.s. administrater privalidges required on both) and delete the new logon account. Hope this will fix the problem, otherwise you have to format your hard disc and reinstall your OS.
Sep 21, 2009 | Microsoft Windows XP Professional
Cant install
Check out this link. It has some downloads that may help you.
http://www.dlink.com/products/support.asp?pid=561&sec=0
Apr 05, 2009 | D-Link DHP-300 Network Adapter
Videocam suite v1.0 download for a Panasonic SDR-H280
I've successfully downloaded & install the videocam suite 1.0 + update from here: http://www.brothersoft.com/videocam-suite-297215.html Thanks to Google!
Oct 20, 2008 | Video Cameras
Drivers for windows vista
This is the translation;
"windows found driver software for the device, but an error occurred while trying to install it, the required section is not in the INF."
Vista Drivers are here
http://www.driverscape.com/download/genius-videocam-smart300-v2
Dec 19, 2017 | Computers & Internet
Problem with the install of vmware
Perhaps it does not say "instmsia" is missing, but instead "instmsi"?
MSI is a Microsoft Installer module native to newer MS operating system installers, not W98 or W98SE.
Regardless, your computer is definitely telling you that you lack some required resources that are mandatory to install the VMware software.
You should read the documentation carefully, especially "system requirements" because you are definitely missing something that is required to use the software. It may be any of the following:
OS: Perhaps the software you have is for Windows ME, 2000, XP or Vista -but not (your) Windows 98.
CPU/Processor Support: Perhaps you have a 64-bit version of software, rather than 32 bit. Your W98 and W98SE are 32 bit-only operating systems. 64-bit software will NOT run on W98x.
Other Software: Perhaps your version of VMware requires a specific DirectX, Java, or other software/version be installed FIRST. And some versions (many actually) will not run on W98x. MS consumer support was dropped for W98, meaning most new MS-software does not run on W98.
RAM/Video: You may not meet the minimum RAM requirements, or the minimum Videa/Display requirements.
I suspect it is the first cause, since VMware that I have used specifically requires W2K or above (and in fact, required the SERVER version of the OS). But that does not mean there is no W98-compatibility in other versions).
To determine what you lack, you will need to read the documentation that came with your software (specifically, "requirements") and/or consult the VMware website: www.vmware.com to find out what are the minimum requirements.
Dec 25, 2007 | VMware VirtualCenter for PC
Kensington VideoCAM SVGA Webcam Logo
41 people viewed this question
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
Alun Cox
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
