Question about Compaq Presario R3000 Notebook
Will not let me Restore windows
Same problem but it will not let me reinstall windows or restore with the OSD it boots then loads all dirvers and then stalls at starting windows screen. even tried a fresh disk of Windows xp Home same thing. Hard diags show disk is healthy. Compaq support is no hepl I change out memory. same results.
    Champion:
  • 217 Answers
Sounds like your hard drive is dead. If you can get to the XP recovery console with the XP cd, try running:
chkdsk /r
(it takes about 30+mins to finish) to repair the hard drive. It should work if you are able to run that. Otherwise it will tell you it failed because of the bad hard drive.
Posted on Jan 28, 2008
My laptop starts up and you can hear it the screen flashes and then goes blank
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
It's also possible that your Master Boot Record is corrupted. To fix, you'll need your Windows system CD:
1. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
2. Once the setup loads, you will see the option to press R to repair a Windows installation.
3. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password (no password, just hit Enter, unless you changed the password).
4. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Also run the fixboot command to repair the boot sector with a new one.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Sep 05, 2011 | Toshiba Computers & Internet
My eee pc has black screen with blinking cursor in top left corner...
Hello.
It's also possible that your Master Boot Record is corrupted. To fix, use your Windows system disk:
Hope this helps.
Sep 03, 2011 | ASUS Computers & Internet
I have an acer aspire one net book. It keeps saying windows could not start \windows\system32\1-intl.nls
Hello.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and the memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
It's also possible that your Master Boot Record is corrupted. To fix:
Hope this helps.
May 11, 2011 | Acer Aspire One Netbook 8.9" Notebook
My laptop comes mup with a blank screen wityh cursor when turned on
Hello.
To access System Restore in Windows 7: Open the Start Menu. Click on All Programs, Accessories, System Tools, and System Restore
Hope this helps.
May 09, 2011 | Toshiba Computers & Internet
I turn on, it comes up with windows failed to start,and says start-up repair required.
This error message means that the copy of Windows installed in your computer is either corrupted or damage and reinstalling or repairing your Windows should fix the problem.
But try doing System Restore first on safe mode before doing a Windows reinstallation or repair to save you from loosing all you files in your computer.
To do system restore on safe mode:
1. Restart your computer and when the Dell Logo comes up and keep pressing F8 until an option shows
2. Use arrows to navigate then choose safe mode
3. Click start button then choose All programs or Program depending on the Windows installed in your computer
4. Click on System tools then choose System Restore
5. Follow the intructions on the System Restore windows on how to restore your machine back to a previous date before this issue happen.
6. Your computer will automatically restart after restore is done
If the safe mode doesnt work then your last option is to reinstall or repair your windows
1. Press F1 to go to BIOS then change boot priority - make sure your DVD drive is the first boot
2. When your done changing boot sequence press F10 to save and exit
3. Insert you Windows CD and and a meesage will appear on a black scrren "Press and key to continue" press any key. Windows file will load and options for Repair or Installation will appear
4. Choose 1 of the option then follow instruction
Hope this information will be helpful. Thank you for using FIXYA.
Apr 14, 2011 | Dell Inspiron 1525 Notebook
When turned on it show black screen and automaticaly shutdown
Hello.
Either you have a memory issue or operating system problem.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
2. When prompted, boot from the CD drive by pressing any key. If Windows loads automatically, you will first have to enter the BIOS setup and change the order of the boot devices to start with the CD drive.
3. Once the setup loads, you will see the option to press R to repair a Windows installation.
4. Once the Recovery Console loads up, you will have to type in a number that corresponds to your Windows installation. This is normally just 1. Press Enter and then type in the Administrator password.
5. Now at the prompt, type in fixmbr. Your damaged MBR will now be replaced with a new master boot record and your computer should now be able to boot properly. Also run the fixboot command to repair the boot sector with a new one.
Hope this helps.
Jan 25, 2011 | Fujitsu LifeBook A3130 PC Notebook
When I turn it on it starts up and then nothing appears no screensaver, programs, just a black screen
Hello.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything will roll back to that date.
It's also possible that your Master Boot Record is corrupted. To fix if you have Windows XP:
First, restart your computer with the Windows XP setup disk in the CD drive. If you don?t have your original disk, borrow one or download a ISO image from a torrent site.
Hope this helps.
Jan 18, 2011 | Sony VAIO Notebook
How can i perform a factory restore on my emachine w3619 without my start up disk..my computer will not load my sims 3 game and it used to be able to i tried everything (including system restore) to fix it
ask emachines for duplicate dvds of your startup disks.
your os is Genuine Windows Vista® Home Basic
any copy of that would work, but you wouldn't have the cyberlink or other software
before doing that
you may first try checking for viruses or startup programs
and then reinstalling any game software
maybe your sims is broken. verify that it works on another machine
Jan 13, 2011 | Computers & Internet
Continuously rooboot itself?
Hi.
When the laptop keeps rebooting shortly after Windows starts loading the reason is usually because the system files loaded by Windows at startup are corrupted.
Windows cannot complete booting and keeps restarting.
The fastest way to Fix the problem is by reinstalling Windows.
If Windows is installed on the same directory of the existing system performing an upgrade installation, the setup process will preserve all personal files, most installed software and settings.
Before reinstalling Windows you can try starting in safe mode (eg. on XP pressing f8 on startup). If the computer starts in safe mode, go to system restore and perform a restore to a date before the problem occurred. Unfortunately when the computer keeps re-booting ut will hardly start in safe mode. Often reinstalling Windows is the only option available.
Aug 02, 2010 | Acer Computers & Internet
Start up problems
it fails to boot-? does it just sit there, or does it reboot continuously? Do you have the os cd for it- you might need it to do a recovery mode and run chkdsk /r that might fix the file error
Dec 02, 2007 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
