Question about Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System
Pink fluid under refrigerator
My refrigerator is not staying cold on the refrigerator side. The freezer side works great. There seems to be a pink, red fluid leaking from under the refrigerator side. Is this related? Thanks for your help. model # 469 5547 We bought it sometime in 1996.
  • 833 Answers
Loklok...no, I don't think so. The only fluid in refrigerators is an oil which is sealed in the cooling system and we know you are cooling. Your fridge may need a full defrost. This occurs because you may have left items uncovered and the moisture condensed in the cooling coils. It could also be the result of improperly sealing doors caused by dirt/ bad gaskets or the like. Best thing to do: shut it off, open the doors and let it defrost fully for a day. Clean the condenser coils under the unit with a long brush. Dry out as best you can and restart. You'll likely be okay. Make sure your freezer side is at about 0-5 above...refrigerator side 35-45. Use a regular thermometer and leave the door closed for at least an hour. (Do these measurements a day after you've restarted.)
Posted on Jan 28, 2008
6ya staff
SOURCE:
The freezer side quit staying cold today. No
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
48" ge monogram refrigerator not staying cold
heatman101
sfjfg
Aug 16, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
Maytag Plus side by side (Model MSD2356AEA)not cooling in
heatman101
hhkgjd
Jun 09, 2009 | Maytag MZD2766GES Side by Side...
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer not cold enough
Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
Dec 29, 2008 | Frigidaire FRT21H8 Top Freezer...
Freezer is completely covered with white ice
sometimes a faulty door rubber can make the freezer work overtime. Does the door close firmly?
Oct 25, 2008 | Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Mar 21, 2008 | GE GSS20IEM Side by Side Refrigerator
Kenmore 25.1 cu. ft. Side-By-Side Refrigerator with Rotating Dispenser System Logo
3,193 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
