Question about Sirius Satellite Radio Sirius SIR-ALP1 Satellite Radio Receiver
Stuck on 255??WTF
I put a new cda 9883 in and sir alp1 existing. The problem is when I turn it to sirius on the source it is stuck on 255 and wont change. Help Please
You need to call sirius and activate the new unit the id number is on the bottom sir-alp1 unit or the box it came in
Posted on Mar 21, 2008
I have my cd changer (alpine) plugged into the input port via ai net cable and I have the output going to the alpine radio (cda 9886) via ai net cable. When I hit the source button everything comes up but...
One thing to verify is that the Ai-Net switch at the bottom of the radio is set to Norm and not the EQ position. And also gray Ai-Net connectors are for audio input and the black Ai-Net connectors are for audio output. It sounds like you have everything connected correctly and at least the Sirius is coming up. And I assume that the CD changer works when connected directly to the reciever so you know that it is working. I would suspect that there might be a problem with the Sirius reciever not allowing the communication signal to connect to the Alpine deck and in that case you would need to get a new reciever. You could check the Alpine radio settings and see if there is something that needs to be changed in order to allow the CD changer to work. If you disconnected the battery connection to the radio then it might have reset the settings to factory default. Otherwise it sounds to me like the problem is with the Sirius reciever.
Jan 09, 2010 | Sirius Satellite Radio Sirius SIR-ALP1...
I just reinstalled my CDA-9883 receiver after removing it from another vehicle. When I tried to use it, I have no sound from the CD Player or the Sirius .
whay type of vehicle are you putting the cd deck in ? if it has a factory amp , it may have one amp per speaker , get the specs on the new vehicle to find out . using a "free harness" is always a good idea as well , it plugs directly into youre vehicles factory radio harness and has labeled wires coming off the end so u know whats what there .
Nov 23, 2009 | Alpine CDA-9883 CD Player
Alpine cda- 9883 radio will not recognize ipod
your ipod might be too new,and your cd player too old the alpine cda 9883 is a 2007 model what kind of ipod do you have,if uyou have an older ipod and got the new itunes9 then try downloading an older version of itunes from itunes.com .....good luck
Sep 26, 2009 | Alpine CDA-9883 CD Player
My CDA-9847 will no reconize the SIR-ALP1 tunner.
I am in the same situation.  I have had my sir-alp1 for 4 years and it simply stopped being recognized.  I called Alpine and they said they have no connection to this piece, it is made by "directed electronics" and I need to contact them.  A new one is around $120 whereas this one was 79 on sale in 2004.  I still have he installation guide/owner's manual for it and nowhere inside is there a number to call them.
Mar 08, 2009 | Sirius Satellite Radio Sirius SIR-ALP1...
Sirius 100 repair manual
my sirius stiletto 100 power on/lock switch slides up and down freely. feels like something came apart inside the device. any solutions?
Sep 16, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Alpine wont pick sirius up
make sure you are set on the correct frequency. both the device and the radio.
Jul 22, 2008 | Alpine CDA-9883 CD Player
No sound
You most likly have the Data cable in one the other or both plugged into the wrong side, this just happened to me the other day with some Pioneer stuff and I had plugged the input outputs backwards. Everything came up as far as sources showing but now sound. That should fix you up Good luck
Oct 25, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
Alpine CDA-9855 won't recognize SIR-ALP1
I also had this problem. I had to go through the menu into the setup and then into tuner settings. There should be an option called tuner area. If you set it to area 1 it should start working. For some reason the sirius only works on area one. Hope that solces your problem
Jun 19, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
SIR-ALP1 problems
the only thing left is the head unit but that is not very likely. Go back to where you bought it from and have them give you new tuner box and anttenna. Sorry man But i put these in all day and its almost impossible for the head unit to be the prob
May 03, 2007 | Sirius Satellite Radio Sirius SIR-ALP1...
Stays on even if HU (CDA-9833) is off
It is possible that the SIR unit stays powered as long as the red wire is powered, since it is normally connected to a switched source. To test this, disconnect the red wire or move it to a switched source (you could even add a switch on the wire and flip it manually). If the battery stays healthy after that, then the red wire being constantly powered is the problem. Otherwise, it is possible there is a problem with the Ai-NET cable connected to the SIR unit.
Sep 26, 2006 | Sirius Satellite Radio Sirius SIR-ALP1...
Sirius Satellite Radio Sirius SIR-ALP1 Satellite Radio Receiver Logo
398 people viewed this question
Top Sirius Satellite Radio Audio Players & Recorders Experts
John
John
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Sirius Satellite Radio Audio Player and Recorder Expert? Answer questions, earn points and help others
