Question about JVC GR-D370 Mini DV Digital Camcorder
NO POWER jvc gr-d70u not powering up replaced battery still no results
  • 30 Answers
SOURCE: jvc digital video camcorder gr-d20ek no power
wipe the contacts with after shave solution or isoprophyle alcohol, this may do some magic
Posted on Aug 15, 2007
SOURCE: JVC GR-D70U Condensation
setting the time & date is useless for this problem. i have had mine repaired 2 times for this & its down a third time for the same reason. to me it appears to be a waste of time & money to try & have it repaired. the best solution is to buy a new camcorder, something other than one made by JVC.
Posted on Sep 17, 2007
I have the same problem and I need a solution. Please, can somebody help?
Posted on Dec 27, 2007
SOURCE: Error message ''condensation operation failed''
1. There is a silver condensation detector in the tape compartment, rear left corner. You can try cleaning this with isopropyl alcohol. I have tried this, and it did not resolve the problem.
2. You can open the camera and unplug the power connector. This will reset the camera, and will resolve the issue for several months. I suggest looking further on this site, where there are instructions for which screws to remove to do this. I have done this, and it has resolved the issued for varying lenghts of time on my GR D30U.
Posted on Apr 13, 2009
  • 3 Answers
SOURCE: Need disk software for jvc gr-d70u camcorder
You don't have to have the software that came with your camera. There are many video capture programs out there. I use Nero Express, but Movie Maker might work too.
I have been unable to import from my camera to my computer for three years, thinking that the problem was the camera. I would plug in the Firewire cord that came with the camera and would get nothing, even on other computers. As a last resort, I got a new Firewire cord today. As soon as I plugged it in and turned the unit to Play, the computer recognized my camera!!!! I am SO excited! When your computer recognizes the camera, it will bring up the programs on your computer that are most likely able to allow you to import the video.
The problem the entire time was the cord! The cord that came with my camera is now in the trash, and I can finally import videos!
Posted on Jul 13, 2009
  • 10 Answers
SOURCE: JVC GR-D70u don't transfer video to pc
At times the "failed to build a preview graph" error measage appears when the editor has a problem with the capture file format. By STUIO 8 I presume you mean PINNACLE STUDIO 8? Try changing your capture settings, like MPEG to AVI or vice versa.
Otherwise download the latest patch for Studio 8 from . It's free if you have registered your copy of the software.
Let's hear from you again. All the best.
Posted on Apr 18, 2010
0 characters
1 Points
Where I can buy a CCD part for my JVC GR-D70U miniDV camcorder ? please replay to thanx
Same problem like most cameras. CCD is dead. Need to replace with new CCD. Now the problem is where I can buy this part.
Jan 26, 2010 | JVC Cybercam GR-D70 Mini DV Digital...
JVC Camcorder- Recording Problems
i have a jvc GR.D20EK and am having problems when recording, it plays back but i cannot record it will play recorded tapes can anyone help me. Thanx
Apr 07, 2009 | JVC Video Cameras
My computer no longer recognizes my JVC GR-D70U mini DV cam when I plug it into a usb port.
Hi, I am not sure. But I believe the camcorder has to be on when you connect to the computer. and I assume you use firewire for this particular camcorder.
I too once had this problem when I used Windows Vista. If you too use Vista, try it with Windows XP.
Sep 19, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Lens cap
You JVC GR-D70US camera has problem with CCD Imager and JVC will repair it free of cost.
Please click JVC Offer for details.
Sep 10, 2008 | JVC GR-D720 Mini DV Digital Camcorder
JVC Picuture gets blurry
The ccd block is starting to fail. Thats the chip thats the eye of the camcorder at the back of the lense assy. Its mounted on a small circuit board. You can find the chip at Its just a matter of dissassembling the camcorder and removing the chip from the board and soldering another onto it taking care not to over heat the chip. You do need good soldering skills.
Aug 24, 2008 | JVC GR-D22U Camcorder
Condensation, operation paused, JVC Video Camera model GR-D70AS
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Apr 27, 2008 | JVC Cybercam GR-D70 Mini DV Digital...
Dec 19, 2007 | JVC GR-D90U Camcorder
Blank screen
your cameras CCD Charged coupled Device is defective go to your nearest jvc service station sandeep
May 08, 2007 | JVC GR-D270 Mini DV Digital Camcorder
How to transfer still photos from jvc gr-d70u tape to pc?
Did you figure this out yet? I am needing help with the same item.
Dec 18, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Problem with JVC GR-D70U
It's ... a. A broken connection. b. A failed chip or component. It is not something an owner usually can repair.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
JVC GR-D370 Mini DV Digital Camcorder Logo
73 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Larry Stiles
Larry Stiles
Shekar Avadhani
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
