Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
POWER UNIT I Took the unit into the shop, and they told me it was a power unit was out. I found a new power unit. ? How hard is it to install? The problem I was having, when I was watching the TV it jus turned off. I went to power it back on. All I got was the green light on that showing power was on. No sound or pitcher. I unplug the tv, thinking it would reset it self. Still the same thing. The repair place wants $580.00 to fix it. I found the part for $210.00
  • 934 Answers
It's not difficult replacing the smps in these units but I would suspect at the $210.00 dollar price that the smps you located is either not built with Sanyo original components or is not a new original smps for that unit, maybe rebuilt.. Both possibilities are not unlikely in our industry.
To answer the second part of your question I would suspect that the smps is the culprit. The most common part in these unit to fail is the smps because they are so tightly packed, not vented well and create a large percentage of the heat.
Hope this helps.
Bill
Posted on Feb 10, 2008
I have a 2001 Cougar with the V-6. It has 145,000 miles. Awhile ago I noticed that a squeaking noise started happening when I would make a right hand turn. I took it to a mechanic and they told me it was...
for one take that shop to court there jucing the hell out of ya replacing the same parts over and over agian. 2nd wd 40 the bushings on the lower connects that will take care of the squeaks and have a mechanic install some grease fittings down there so u can grease them. apparently in the turn of melinium cars the didnt come stock that way from the factory. meaning u had to have a mech do it when the part wore out or broke found that out the hard way. take you recipets and take those ***** mechs to court then use that money and get it done right
Sep 30, 2011 | 2001 Mercury Cougar
I have a 2006 Thomson/RCA ModelM50WH72S TV that we have replaced the lamp, it still does not work and a technician has told us that we need a light engine for it. How can we locate one?
have the same tv,, power light blinks, book said it was bulb, bulb didnt fix it,took it to tv repair shop, they found a bad capacitor, replaced it with a higher heat range capacitor, this capacitor was on the power board for the lamp circuit, repair was $200, not bad since i paid $1500 for the tv, other than that issue, just replaced a couple of lamps
Dec 28, 2010 | Televison & Video
I would like to find an electrical schematic for a model JES1036PWH03 GE microwave oven. Oven is dead, no power to control panel or light. Power thru fuse is good.
Couldn't get a schematic from GE. CSR told me they consider the unit a throwaway if it fails. Only parts they stock are the glass turntable and the roller ring. I ended up probing and metering the 110v power circuit. I found an open thermal cutout that was preventing power to the control panel. I removed it and took it to a local parts store and matched it up with a generic cutout with the same specs. Installed new unit and the oven is working like new. Cost: $15.00.
Oct 05, 2009 | Microwave Ovens
The player will start with the power button on the unit the dawer will open and close and the unit will load and start running but the remote does not seem to work to start the unit. new batties wer...
Check that the batteries are inserted properly and that they are in the right way, if either of the batteries is not in the position its ment to be, it won't work.
you would need a Special IR camera to see any light from the remote so that seems like a silly solution to me.
The remote is not working if you can't turn the device off or change channel. You might want to try another remote to confirm that your device actually receives the signal and works, if it does work with another remote, the remote you have is broken.
Aug 27, 2009 | Televison & Video
I had my head unit put in by a audio shop and when i got my car (1993 Saab 9000 CSE Turbo) back my rear speakers dint work so i took the head unit out(because the shop would not fix it or refund me and i...
If the rear speakers worked before your new head unit was installed, then the first question is does your new head unit have the facility to feed four speakers. Some systems will only power two speakers. The Audio Shop should have rectified the fault - you paid for the installation and as the customer you have a reasonable expectation that they would do it properly and ensure that all of the existing speakers were functioning properly. It would be worth challenging them again - if they refuse you could go to Citizen's Advice Bureaux or the nearest Trading Standards Office. Alternatively, try tracing the wires back from the rear speakers to the head unit - are the wires connected up properly... at both ends (i.e., the speaker end and the head unit).
The audio shop has probably hard wired the head unit because the sockets in the back of the head unit were not compatible with the plugs that came as standard with the car. A Haynes Manual or equivalent will give the colour codes for the various wires for the audio system.
Jun 26, 2009 | 1993 Saab 9000 Hatchback
Power problems with eclipse avn 5500 to amp
the avn 500 does not have a sub output. they have to create one at the shop-
Mar 24, 2009 | Eclipse AVN5500 Car DVD Player
Pin 570 wont boot after hard reset
RECENTLY I DID PRETTY MUCH THE SAME THING
SO HERE IS WHAT I DID :
" I TURNED IT ON AND HIT THE HARD RESET AND THEN LEFT IT ON TILL ALL P[OWER WENT AWAY FROM UNIT
SECOND I HAD TO DOWNLOAN A NEW VERSION FOR MY UNIT ; MEANING MAP
THEN I TOOK THE BATTERY OUT AND AND PLUGED IN MY USB CORD AND IT TOOK IT
I PUT MY BATTERY IN AND CHARGED OVER NIGHT AND WELL IT SEEMS LIKE A LOT TO DO BUT FROM WHAT I UNDERSTAND MY DRIVER GOT BOOTED OFF THE UNIT AND ANOTHER DRIVER FOR A MODEL WAS ATTACHED
HOW I DONT KNOW BUT MY UNIT WORKS NOW FOR THE LAST 4 MONTHS NO PROBLEMS
HOPE THIS HELPS YOU OUT RICHARD FROM CHICAGO
Mar 30, 2008 | Navman PiN 570 GPS Receiver
Accordianman--Dual deck VCR not responding...
No. Sound like the Switch mode power supply is or has failed, to repair this would involve replacing capacitor and or some componets, Many repair shops these days have discontinude repairing VCR's becuse most of the time you can replace the entire unit for the cost of repairing it
Feb 24, 2008 | Televison & Video
Dell 4201c power problem
I am an actual Dell repair tech for a non-Dell refurbishing company. I fix this model exact model, as well as all the other plasma TV's that Dell has come out with. If you are looking for a replacement part I suggest starting with either the power supply. But if you are electronicly inclined, I suggest taking voltage measurements across the labeled parts on the power supply that are the following: VS, VSCAN, VSET, VE, and VA. These correct voltage measurements are labled on a sticker in the top right corner of the TV. If they all come out right then your best bet would be the Y-main board with both upper and lower buffers. They are the circuit boards on the left hand side of the TV. As far as getting the parts, thats a whole other story but I hope this helps to narrow down your parts search.
Feb 03, 2008 | Televison & Video
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
85 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
