Question about Kenmore Elite 45986 Front Load Washer
Washer does not drain completely.
Replaced pump on Kenmore HE3 Washer. Problem better but drain cycle does not complete. Drain cycle shuts down midway in estimated time schedule. Any ideas? - 2 Much Laundry
I recently had a slow draining Kenmore elite heavy duty Catalyst washer that did not drain when cycle was complete. It turns out I had a clogged 2-way valve. You can find the valve by tilting the washer back the pump is towards the front conected to the motor. You will see the line that comes from the basket that is the intake side the bottom side of the pump is the discharge. Follow the discharge line back to where there is the two way valve it is covered in two pieces of black plastic one on top one on bottom. Make sure the washer is unplugged this is an electronic valve. Using water pump pliers disconnect both hoses going into the valve. Be prepared to have water come out you may want to take the hose off the discharge side of the pump it will be easier to collect the water from here. To check for lint in the valve slide your baby finger in to see if you meet obstruction you can open the valve by pushing on the lever on the bottom side of the valve it has a spring attached to it. Be sure to check from both sides of valve. Be prepared to spend a little time trying to dig out the lint I used needle nose pliers with a bend on the end of it and it took me about 15 minutes to get it all you can try a screw driver, tweezers what ever you can to get it out.
Posted on Feb 09, 2008
I'm not sure if this is the same model as our but I will let you know ours did not drain all the way and kept stopping, not completing the cycle. We found that if you take the bottom of the front of the washer panel off thre is a circular looking thing, it happens to be a trap for waste, sort of like the dryers lint catcher. Make sure you put something under it befor you loosen the cap water will come out. When we took the cap off, it was filled with gunk and we cleaned it out and the problem was solved!!!! Amazing because we tried everything , called everyone and not one person even mentioned we had a trap in the washer... It should be right in the center when you take the front lower panel off.. Good luck and let us know if it works for you..
Posted on Jan 28, 2008
I have a kenmore elite HE3 washer. I was getting the sud error and then eventually F02. I cleaned out all the drain lines and pump filter trap and this did not help. I've now replaced the pump
I endevor to purchase a new unit. I've had the same electrical issue with the "F" variable coming up for EACH cycle. I've pressed the Pause/Cancel button and attempted to resume the cycle. While that did work, again, the "F" would come up and the cycle disrupted. I think I will end up paying quite a bit to have it serviced. My washer is 7 years old and I've had it serviced twice to date. I intend on purchasing new in the New Year, a Samsung or LG.
Nov 24, 2012 | Kenmore Elite HE5t Washer
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
Jun 01, 2010 | Washing Machines
My kenmore HE3 front load washer will not drain or open door
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore elite HE3 front oading washer says 02F
"F02" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
Sep 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 washer stopped at 11 minutes left in cycle and just hums. Won't drain rest of water or spin out. Help!
Something must be stuck in your pump's impeller and not allowing to spin and send the water down the drain. Remove the rubber boot seal and check the impeller for obstructions. The pump is located at the base of the washer on the right side.
Aug 21, 2009 | Kenmore HE3T Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3t washer not working properly
ok lets see here im onthejob,,i take it that cycle stops with suds..ok first are we using he or low sudsing detergent,,,next when you clean pump filter did you check pump wires for defectives,,,try and bleach unit out to get rid of slugg...also check connection to pressure switch,,and ccu...keep me posted..onthejob
Jan 04, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
464 people viewed this question
Sal De
 Brian Main
Brian Main
