Question about Vacuums
Hoover Mach 5 sweeper
Stopped while using it. I checked the cord. Checked the fuse box. Found a clog. Took it apart and removed the clog of hair and carpet fuzz. Still does not work. Is there a fuse in this piece of equipment? Husband "put" the book away. Who knows where. If it has a fuse, where? Thanks
  • 1 more comment
  • Anonymous Apr 30, 2008
    I have just had the VERY same problem. How do we fix this???????
  • redmel Jun 03, 2008
    I am just starting to have the same problem. While using it will just stop and won't start up for awhile. We checked for clogs too. After awhile it will work again.
  • James Smith
    James Smith Jun 12, 2008
    Same problem here. I took it apart got the plug of carpet out and cleaned it with my air compressor. Still doesn't run.
Hey all...
Had this same problem with my Mach 6 (same as Mach 5)
It would shut off after 15 min of use. What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Posted on Sep 24, 2008
  • lin58 Mar 06, 2011
    Thank you, j_luke78! We took ours in to have it looked at and were told it needed a thermal sensor. We were debating whether to pay to have it fixed, fix it ourselves, or to buy a new one. Using the model and part names, instead of a price for the part, we found this website. We followed j_luke78's cleaning/maintenance instructions and now our vacuum works like new! We saved at least the cost of the part, if not professional installation, if not a new vacuum. Thanks so very much!
    Problem Solver:
  • 5 Answers
*j luke78
i had the same problem and fixed it using the above instructions.
i overlooked the second filter. it's inside the machine, up above the area where you took the dust canister out.
exactly as you said, it felt brand new.
thank you for your solution
Posted on Mar 11, 2009
Yah the thermal coupler is right next to the flux capacitor....
Posted on Jun 29, 2008
I washed both filters using some mild dish washing liquid and let them dry thoroughly. Before you use water to clean them make sure you "beat" the worst of the dust out of them first by gently tapping them on a hard surface OUTSIDE your home as they are very dusty. (stand up-wind if you are smart ;) ) Don't be afraid to squeeze the sponge-like filter until the water comes out clean and forcing some water through the other part of the filter as well. Just don't be too rough, and do it by hand, I would not recommend running it through a washing machine! This is VERY easy to do and should probably be addressed every 6 months or, not when your vacuum starts shutting down on its own!
Posted on May 27, 2010
Your concerns about the "shutting off" while in use is simply due to the "overheat sensor" that this model uses. It's just a safety thing. Wait about 15 minutes till the motor cools down and it will work just fine.
Posted on Jul 22, 2008
There is sometimes a thermal coupler inside the machine.
Posted on Feb 01, 2008
And what is a flux capacitor ? and where are these located ?
is there a reset button on this machine ?
Posted on Sep 05, 2008
Same problem with my Hoover Mach 5 fusion sweeper.
If you're looking for help from a vacuum repair place, forget it!
They are protecting their business. Everyone I called knew the problem and said its a simple fix, but would not say another word unless I brought the unit to them to fix.
This vacuum is awful. Mine constantly shuts off after a few minutes of vacuuming. I have another vacuum that works just fine for hours! This one is ridiculous as I can't even get finished with a room before it cuts off.
Posted on Sep 19, 2008
I have a Hoover nano cyclonic vacuum. I completely lost suction and found the hose was clogged to the max. After removing it and changing the filter I tried to use it and it picked up dust but not much...
If the hose was clogged there's a good chance the head was clogged too. Try to stick a bent coat hanger or other semi-rigid piece down the throat at the top of the head to push the clog out through the mouth. You might have to remove the beater bar to get the clog out.
May 20, 2014 | Vacuums
Using hoover, stopped working. Bag very full so changed. Hoover seems very hot. Will not work. Checked fuse
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Apr 04, 2011 | Miele Cat & Dog 326i Bagged Canister...
WE BOUGHT THE HOOVER CARPET CLEANER SPIN SCRUM. NOW IT WILL NOT PICK UP WATER. CHECKED ALL FOR CLOGS . FOUND NONE WHAT ELSE CAN BE WRONG?
i had this same one, i took it apart, and found that the gasket for the tank had dried out, when that happened it cracked, i think that this is a bad design flaw, and they should have a recall, but you know that wont happen.
Mar 27, 2011 | Hoover Vacuums
There is a suction problem - the suction power is very low. The filter has been washed, dried and replaced but the problem is still there What is the problem? Thanks.
Something between the bag and the suction opening is clogging the vacuum. Start at the bag. Remove the bag and check for a clog. Remove the hose from the back and check for clog. Release the handle and turn the machine over to expose the sweeper bush. Check for clog. If you haven't found the clog at this point, remove the 4 screws on the brush cover. Then remove the brush and check the hose going into the machine. If the filters are clean the machine should have plenty of suction.
Nov 27, 2010 | Hoover Vacuums
Hoover Mach 6 stopped running and won't start up. Cleaned the brushes(roll freely) and checked for a clog but couldn't find any.
it doesnt look like that vacuum has a reset switch on it. id start by checking the cord, then move to the switch, then check the motor
Jan 02, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
Purchased a Hoover Mach 3 upright sweeper which gives off a odor
Return it immediately and run the unit with a store rep as witness.
Dec 30, 2009 | Vacuums
Hoover mach 5 turns off after 10 minutes of use
I have had problems with the belts on my Mach 5 overheating (smell of burning rubber) and also with the motor overheating and shutting down.
I learned the hard way that one of the issues might be that the roller/brush on the bottom of the unit has a metal bearing inside the roller/brush that can become clogged with hair (both human and pet hair) which effects performance of the unit.
Another item to check is if your dust filter is not plugged up which is located behind the removable dirt cup. This is the cup that you remove that collects the dust/dirt/hair from your floor. Take the removable dirt cup out by depressing the gold button and then look behind where the dirt cup sits for filter. This can be cleaned out by washing it with soap and water in the sink but make sure you let it dry overnight before placing it back in the machine. This probably causes some of the overheating when not enough clean air is passing through the machine.
It’s fairly easy to fix.
Lay the vacuum on the floor so that you can see the roller/brush. Then remove the phillip head screws that hold the protective plastic plate over the roller/brush. (There are about 6 screws that hold this plastic protective plate in place) Also, you will be removing the (1) screw that also holds the plastic plate over the belts. There are (2) belts that you can remove and when in doubt replace these (2) belts for around $9.00.
Once you have the protective plastic plate off that covers the roller/brush disconnect the belt is around the roller. Take the roller and cut off any hair that is wrapped around the roller. Next, grab the roller by each end and twist the ends caps and (1) of the ends will unscrew. Once you have unscrewed one of the ends remove any hair or dust that is trapped under this cap. (Be careful not to lose the small metal washer that sit on top of the bearing)You will notice under this cap is a metal bearing that can become clogged and jammed with hair. The hair should come out fairly easy and allow the brush to spin fairly easy once you have screwed the end caps back in place test that it spins freely. If it doesn’t spin freely replace the roller/brush with a new one for about $23.00.
When you put the belts back on the thick rubber one (Belt # 40201-271) has probably become stretched and should be replaced for about $3.00. The small diameter belt that goes over the roller/brush probably does not usually need to be replaced and does not usually fit very tight. I have heard that people will take the small roller/brush belt and turn it upside down to get a better fit.
I just did this on my Mach 5 and it runs like a new machine. I did end up replacing the roller/brush head.
Hopefully you will find this useful.
Oct 01, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
My hoover mach 5 stopped during use and will now not turn on
If the machine overheats, a breaker trips. Most breakers reset themselves after they cool off. You may have a manual reset button to push on your model. The machine will overheat if the bag is too full, or if the exhaust port is clogged. The reset switch is usually on the back of the motor housing, near the footswitch.
Dec 22, 2008 | Hoover Commercial C1660-900 Bagless...
My henry hoover has just stoped working its not the fuse do you have any ideas
I had exactly the same problem.there were no burning smells coming from it so nothing seemd obvious.I then took it apart and checked that all wires were connected,which they were.Then decided to check the plug.After replacing the fuse I chopped the cable of (as it is a seald plug) and connected up a new one.Hey Presto,Henry was alive again.Hope this helps.
Nov 03, 2008 | Hoover Vacuums
NO SUCTION
took mine to repair shop for this problem. Dog and people hair caught up in housing you can't reach.
Oct 28, 2007 | Hoover U8143-900 Upright Vacuum
Vacuums Logo
1,179 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
