Question about SanDisk Sansa E280 MP3 Player
Freezing twice my sanDisk Sanse has frozen up that nothing will shut it down I am not sure how it resolved the fist time (timed out) but this time it won't even turn off. I don't remember anything different that I did except charge it over the weekend. What can I do - just purchased it this past holiday..
The product is a piece of shi*! Thorw it out!
Posted on Feb 02, 2008
  • 4 Answers
Get a new one that is all i can tell you
Posted on Jan 28, 2008
6ya staff
SOURCE:
Play dota
test this steps and fix it. God bless you
1. The Mouse o There are two examples of a computer freezing up. One is when a single program on the computer is frozen, while the other is when the entire system freezes up. To determine which type of problem a computer is experiencing, attempt to move the mouse on the screen. If the mouse pointer is visible and moves, the issue is with a single program. To determine which program is frozen, bring up the Windows Task Manager. This can be done by right clicking a blank area of the taskbar and selecting "Task Manager," or by pressing the keyboard shortcut "Ctrl+Alt+Delete" and selecting "Task Manager". The program or programs that are frozen will show as "Not Responding" on the Applications tab of the Task Manager. Click the frozen program and click "End Task" to close it. Visit the program's website for specific troubleshooting tips if the program continues to freeze. If the mouse pointer is stationary on the computer screen, the entire system is frozen.
Unfreezing a Frozen Computer o If the entire system freezes up, it will need to be rebooted. To do so, hold down the "Ctrl" and "Alt" keys. While holding both keys down, press the "Delete" key twice. This should shut down the system and automatically restart it. If the computer does not respond, try the keyboard shortcut once more. If it remains frozen and does not reboot, you will need to perform a hard shut down. This simply means pressing and holding down the power button until the computer completely shuts down. Once it has shut down, leave it off for a few minutes and then turn the power on once more.
Continuous Freezing o A frozen computer might be a one-time occurrence, or it could be the sign of a more serious problem. If the computer continues to freeze up, there are several items that should be checked out. The first step to take is looking at any recently installed software. Programs such as freeware or shareware often contain malware that can damage the system. Even reputable software can contain a damaged file. Uninstall recently added programs and determine if that was the cause of the computer freezing up. To uninstall a program, go to the Control Panel from the Start Menu. Select "Add/Remove Programs" in Windows XP or earlier, or "Programs and Features" in Windows Vista. In the list of installed programs, select the one to be removed and click "Uninstall." Follow any prompts and restart the computer when the process is complete. Next, update and run both the antivirus program and spyware removal program installed on the computer, or use the link provided in resources. Check the Windows website and download any updates.
System Tools Finally, you will want to check the available space on the computer's hard drive and use the built-in error checking and cleaning tools. Go to "My Computer," right click "Local Disk (C:)" and click "Properties." On the "General" tab, make sure there is sufficient free space. The "Disk Cleanup" tool will free more space by deleting unnecessary files. Click the "Disk Cleanup" button to run the tool. On the "Tools" tab there are more tools that can solve the problems causing a computer to freeze up. The Error Checking Tool finds and corrects hard disk errors and the Defragmentation tool will reorganize system files, helping the computer run better.
Jul 24, 2013 | HP Computers & Internet
Refrigerator runs almost all day
Your refer will run about 85% of the time, But if your refer items are freezing i would recommend you replace the refer t-stat. The only time your unit will shut down is when it's in a defrost ( about every 8 hours for 30 Min's or less ) and by your t-stat when it reaches temp, if you have it set to a warmer setting and it's freezing you items then for sure you have a bad t-stat. Hope this helps you
Jan 01, 2009 | Refrigerators
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa disk e 260
I had the same problem with mine freezing. It happened when I kept pressing the back track button (on left side) to go back to an earlier song. It then froze in the middle of a song, couldn't hear the song, the time of the song was frozen, etc., and the unit stayed lit, despite pressing all the buttons. I tried holding down power but nothing happened. I read another person's post that you need to hold it down 15-30 seconds. I did this and it worked, you just have to hold it down until it shuts down, which was about 15 seconds as suggested, could be longer for others.
For me, next time I wont keep clicking the tracks repeatedly, I'll simply go out of the song and back to the song I want through the menu.
Thank you for the good posts. Glad I didn't have to mess with the battery like others....
May 14, 2008 | SanDisk Sansa e260 MP3 Player
Screen frozen
I would recommend you to go to the sandisk site to update the firmware on your device even if you have done so in the past or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 03, 2008 | SanDisk Sansa E280 MP3 Player
Help
You will need to reset your device and also get a firmware upgrade on your device.....To reset the device when it freezes just hold the power button down for 15-20 seconds or until it resets....the latest firmware for the device resolved much of the freezing issues....also there are two modes for you to use the device the msc and mtp.....try deleting in mtp mode.
Jan 03, 2008 | SanDisk Sansa e250 MP3 Player
Sanse e200 freezing up for no reason!!!
Hi. It seems like your player decided to throw a hissy fit by deciding to experience internal system errors. Best that you reset the firmware. Here's how: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E250, just like I do. (I love this player)
May 14, 2007 | SanDisk Sansa e250 MP3 Player
Frozen MP3
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
May 12, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
