Question about Refrigerators
Whirpool refrigerator runs too long
Our Kenmore Coldspot refrigerator is made by Whirlpool. It was made in 1999. The unit seals seem fine, no air leaking, but the unit runs between 30-40 % of the time. I hear it running for long periods in the middle of the night.
It performs properly except for the noise and high energy usage.
Any suggestions?
  • mpgsct Dec 06, 2008
    My Kenmore 2001 freezer on top of fridge starts every five minutes and runs for about fifteen minutes. The motor seems louder also. I don't have much food in either half. This all started about six weeks ago.
    Thank you for your suggestions.
    Jae
  • 63 Answers
First thing is to check the condenser coil( outside coil) and see if dirt has accumulated on it. if so clean it off. The condenser coil should be located under the fridge, or behind the fridge.If you do clean it, and its still running a lot, then its possible that the unit is low on refrigerant. If that's the case you will have to call a service tech to look at it
Posted on Jan 28, 2008
6ya staff
SOURCE:
"I have a kenmore coldspot model 106.54382300. The freezer is working fine, but the refrigerator doesn't seem to be cooling. We just bought this used and it has worked fine until tonight, when we finally...
Can you hear a small fan blowing air inside the refrigerator? It sounds like the evaporator fan has gone out and it is not transferring the air from the freezer to the refrigerator in order to cool!
Oct 09, 2014 | Refrigerators
I have a kenmore coldspot side by side. the refrigerator part is not staying cold. there is condensation inside. the freezer seems to be running fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 27, 2011 | Kenmore Refrigerators
The kenmore coldspot side by side refrigerator is cold but run 24/7 non-stop and I just replace the new control thermostat but it still run 24/7 and what parts to solve this problem?
I would check your condensing coil(usually found underneath unit, remove kickplate below doors) It may be dirty, which will reduce sytem capacity. Also, if you have worked on unit rear, insure that back cover panel is properly installed so airflow will be right. Other than that, if you are cold enough in freezer(ice cream hard), you may want to check gaskets for proper seal/ no tears.
Nov 22, 2010 | Kenmore 53642 / 53644 Side by Side...
Coldspot model: 78202891 07/1999 runs all the time.
No, that is not the nature of an old fridge. I would seriously consider a service call before throwing it in the landfill
May 01, 2009 | Refrigerators
Freezer okay, fridge warm
May need defrosting, so do that, and also unplug the unit for 9 minutes, as this should reset anything that might have affected the problem. Check with Kenmore customer service department on how long the unit takes to get to a set temperature after resetting and consult your manual on your warranty options.
Mar 01, 2008 | Refrigerators
Refrigerators Logo
146 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
