Question about GE Spacemaker JVM1640SJ Microwave Oven
Issues with GE Spacesaver Model JVM1533D002
Have one of these dated 2002. Occasionally the turntable will not turn and when this happens, it does not heat the contents. I've narrowed the problem down to something that is tripped when the door is closed because if its acting up and I wiggle the door or open it slightly and leave it move back into the closed position it starts to operate fine. I know there is some sort of switch in there at least on the bottom latch hole, as I can push it with a pencil and hear it clicking. Does the top hole have a second switch, If so I'm not hearing any clicking? Anyway, I'm looking at the parts diagram, and I am not sure if I need to replace the Switch or the Switch Monitor. Also, how are these parts accessed, do I need to drop the unit to a table, or can it be done while the unit is hanging. If I do need to drop he unit how is the cover removed. Thanks
  • MadDog16 Jan 28, 2008
    Thanks sedonix, how many switches are there one or two? I assume that I do not need the Switch Monitor then.
  • 579 Answers
Yes, the door switches need to be either adjusted or replaced. Will require dismounting it and taking off the cover which is about ten screws around it rear and side edges.
Hope Ya Fix it.
Posted on Jan 28, 2008
  • Greg Collins Jan 28, 2008
    The same part is used for both switches. Probably just one of them is the problem.
My turntable on my GE Spacesaver xl1800 isn't turning...there is a noise which happens when it tries to turn....is there something that I as a homeowner can do instead of calling a repair person?? thanks
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Nov 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave Oven - JVM1650WH05 - Turntable does not work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My spacesaver dated September of 2004 shuts off
I solved the problem by buying a new microwave and it was not a GE. I feel that GE should have had a recall on this problem, since it seemed to be a major problem in their system. I will never buy another GE product.
Oct 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver microwave table wont turn
either your turntable motor part# WB26X10037 G.E. is bad or the motors capacitor part# AP2026076 is defective they are both the same price
Oct 08, 2009 | GE JVM1440 Microwave Oven
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacesaver turntable will not turn
my mocrowave turntable will not turn but it will heat up.
Dec 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Repair turntable for spacesaver XL1400
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
96 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
