Question about Olympus ? Stylus 500 Digital Camera
My Olympus Stylus 500, doesn't work the flash
When I take pictures, not everytime the flash work, sometimes. When I press the button for taking picture, most of time the flas doesn't work in any mode (automatic, etc.)
  • Anonymous May 02, 2008
    Olympus Stylus 500 will only flash when it wants to. So the pics come out dark at night and to bright during the day.
  • InParis Jul 11, 2008
    Mine seems to be doing the same. Sometimes there's overexposure and other times underexposure. I can't seem to find a reason as I've tried troubleshooting the same object under the same conditions and getting various results.
  • 871 Answers
Hi
have you tried using lithium batteries? alkaline batteries. just try out different batteries. if it is still the same, have your camera checked in a service center for maybe it needs a replacement or there is something loose inside.
hope this helps.
Posted on Jan 28, 2008
6ya staff
SOURCE:
OK button on olympus stylus 710 not working
It's possible some debris has gotten under the pad that would activate that button. My first try would be a direct blast of air from a pressurized can of duster. Sometimes it may take several shots from different angles. if this doesn't solve the issue it may be hardware related and would require a technician.
Aug 06, 2012 | Olympus Stylus 710 Digital Camera
How do i shut off the flash?
Press the Menu button Then press the left button. Press the left button repeatedly to change the flash setting.
Jul 19, 2010 | Olympus ? Stylus 500 Digital Camera
My olympus stylus 500 wont take pictures.
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $78 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 02, 2009 | Olympus ? Stylus 500 Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Flash-Off Problem
Do you have the camera in the auto mode?
Did you check to make sure that the auto focus is not in the manual mode when the flash is turned off?
If the above does not comply, call the tech support for the camera.
There is also a possibity that there is a defect, or that the flash is part of the auto focus function.
Jerry G.
Sep 15, 2008 | Olympus ? Stylus 500 Digital Camera
Olympus µ Digital 500 flash is not working. Flash indicator keeps on blinking. But when the flash is off, the camera can take pictures. I also notice that the battery and memory card get hot when the...
This suggests the flash capacitor has malfunctioned
Check Olympus for a warranty replacement or repair cost- according to age of camera. If it is an older model a new camera may be best bet
Dec 20, 2007 | Olympus ? Stylus 500 Digital Camera
OLYMPUS 410
It is something that seems to be a problem with the Stylus 410s. Olympus will not repair them unless they are under warrenty, I've tried. My best advice, and what I am in the midst of myself (I have 2 of these with the same problem) is to file with the BBB. Perhaps if enough complaints come through, they will begin to fix the stylus 410 defect as they should. Good luck. =)
Oct 13, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Flash indicator keeps blinking
i have the same problem. i dont think the flash is working.. i think the bulb needs replacing. i wish i knew a place to get it fixed or a place to buy a bulb...
Aug 05, 2006 | Olympus ? Stylus 500 Digital Camera
“Shoot and Select” Modes
e “shoot and select” modes allows you to select an image out of a sequence of still pictures you have taken by depressing the shutter button and storing it. This is best for shooting moving objects. SHOOT & SELECT 1: Shoots a rapid succession of 4 still pictures by keeping the shutter button pressed. SHOOT & SELECT 2: Shoots a succession of still pictures by keeping the shutter button pressed. The Stylus 500 will continue to shoot until you take your finger off the shutter button or until the card is full. After shooting, you will have the option to immediately delete the pictures you do not wish to keep.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Review the pictures
Press the QUICK VIEW button. The last picture taken is displayed. Use the arrow pad to display other pictures. Press the QUICK VIEW button again when you are ready to take another picture. Using the Mode Dial Turn the mode dial to the playback option (the green arrow). Use the arrow pad to navigate to your picture of choice.
Olympus ? Stylus 500 Digital Camera Logo
174 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
