Washing machine hi i have a sservis washing machine i put a load of clothes in and was working fine then i put some towels in and it went throught the cycle at the end it drained the water out the drum was rotating but it did not go into the spin
  • Anonymous Mar 29, 2014
    Set the machine to wash...it puts water in, does two revolutions of the drum then drains and puts more water in and repeats the process
  • 126 Answers
Check the brushes in the motor.
Posted on Jan 28, 2008
My bath towels have an unpleasant smell after washing and drying. I have tried a few things but am sick of trying,
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
May 12, 2014 | Samsung Washing Machines
Duet washer , clean filter still get sud reading. Washes well without clothes. Wash with and without soap and did not put in clothes. The machine went throught the cycle with no problems. When you
do you get a lot of suds when you run it without soap and clothes ? if so put about a cup or 2 of vegetable oil into the washer and run a cycle . soap suds will adhere to the oil and it will help it to remove from washer . after you can run a clean cycle with bleach or white distilled vinegar.
Feb 20, 2013 | Washing Machines
Washer won't spin. Washed bath mats (small) and
Read a post from someone else on this - turned out it works fine, just wouldn't work with the small wet load. I added towels to the bath mat load, washed them, it spins fine. Washed clothes & that worked fine too. Yay!! Not broken. Just not found of small loads of bath mats!
Jan 22, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore 80 Series Mod:110.23832100 top load that with heavy clothes (towells robes) won't drain and leaves excessive water after spin cycle. Everything appears to function otherwise, no odd noises. No...
When you are putting the heavy clothes (towels robes) the sleeves of the towels will come out easily and get stuck in between the drain out valve so it will not sent the water out properly please avoid heavy clothes(towels robes) try to give a normal load
Dec 23, 2009 | Kenmore 15864/15862 Top Load Washer
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Kenmore frontload works with no load but fails with clothes
Suspect the drum motor. Sounds like a burned winding in the motor which will open when hot and not work under any load.
Mar 26, 2009 | Kenmore 24032\24036 Top Load Washer
Smelly clothes and machine!
Do you wash whites separately or with bleach? Sometimes changing up the loads to whites with bleach would kill the germs.
Jun 12, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Total Power Shut-Down - Can't get it to come back on
Hi , recock the breaker ,one the line was disengage..
Jan 27, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
