Question about Tascam 2488 Portastudio Multitrack Recorder System
Tascam 2488 SDRAM error
I have a Tascam 2488 that stop working. I get the following message: "Device error, CODE: 04, SDRAM Initialize Error".
The only thing that comes on is the display with this message after 15 - 20 seconds. There is no hard drive activity at all. No other light comes on. Please advice on what the problem is. Is there anything I can do to fix it besides taking it to an authorized service repair center. I tried to look for the error code but could find it. Has anyone else seen this problem? Is there a repair manual for the T2488?
Thanks,
Jose
  • tony cooke Feb 11, 2009
    yes i have the same problem code 4 sdram
Jose
I had the same problem. I sent it back to my place of purchase and they sent it to an authorised Tascam repairer. Unfortunately they sent it back twice saying it was fixed when it wasn't. They then decided it needed a ne main board which was going to cost $800 AUS, excluding any labour to install it. In the end I got angry and went straight to the TASCAM distributor and told them my problem and that it was unnaceptable that such an expensive unit needs a new main board in such a short space of time. To my surprise they came back and agreed to replce the main board for fee and the service repair centre did not charge me either. DON'T pay for this. It is obviously some problem with the unit. RING TASCAM in your area or the authorised distributor.
Hope this helps.
Posted on Feb 10, 2008
Tascam 2488 system error code 1
I had
System error code:01
on my Tascam 2488 neo
Turns out it was a hard drive error. I tried everything. I used the "Quick Routing/Shift/Send/ShutDown" trick where you press all four buttons at once and keep them pressed down throughout while you power on the unit util you see a message saying "System Reset Complete. Now Power Down". Numerous times it came on and said stuff like "creating partition," "creating song" and "now working" but it always ended with "System Error Code:01". That trick is upposed to reset system par?meters to default and erase everything from the hard drive and reset the hard drive. I even removed the hard drive, hooked it up to my Windows 10 PC and used Windows utils to reate and/or delete partitions and both "quick" and regular format. I also tried all the hard drive utils from the manufacturers like a formatting and a scrubbing util etc.,.nothing ?orked until I downloaded, inst?lled ?nd used a low level format utility called "Hard Disk Low Level Format Tool," its installation file is called "HDDLLFsetup.4.40.exe" which is available from mul?iple internet sites, just search for it. Here is how to repair your Tascam hard drive or prepare any new hard drive for installtion or upgrade that is giving endless problems and system error codes on the Tascam:
1. Open your recorder and remove the hard drive from the Tascam. If you're unsure about doing this there is a YouTube video av?iable about how to replace your Tascam 2488 hard drive.
2. Connect that drive by any means available to your laptop or PC. I used a USB to SATA ad?pter and connected it to my laptop, I also successfully did this using my desktop PC.
3. Run the "HDDLLFsetup.4.40.exe" application and install it.
4. Now use the newly installed "Hard Disk Low Level Format Tool" utility.
5. Select your hard drive then the low level format tab and don't sele?t the "quick" option, make sure it does a full low level format. It'll be slow and t?ke some time. Any hard dive prepared like this will ?ork in the Tasc?m except incompatible or damaged hard drives.
6. Reinstall hard drive into Tascam and simply power on the Tasc?m. Do not use any special boot up tricks with any key combinations, just turn it on.
7. Select "yes" when asked if you want to form?t the drive. W?it a few seconds until it completes cre?ting and working. It should boot up to normal use mode and be ready for recording within 3 minutes. If yours takes longer your hard drive may be damaged and need replacing. I tried other hard drive utilities from Hitachi, Seagate, S?msung and Western Digital but none worked. O?ly the "HDDLLFsetup.4.40.exe" was able to fix the problem.
Dec 15, 2012 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 mk2 [auto repair program]
alors c'est quoi la solution car moi pareil !!!
Jul 07, 2012 | Tascam Audio Players & Recorders
If I plug in powered monitors to the digital input... will it get rid of my error code 02 displayed on the screen ?
Never go from a PA (powered (amplified)) speaker signal to the inputs of a recording device. This can severely damage the electronics of the input/preamp. That error code may be getting caused by something else. For more details on how to use digital ins:
http://en.wikipedia.org/wiki/S/PDIF
Apr 13, 2012 | Tascam 2488NEO 24 TRACK RECORDING...
I want to erase all of my data on the tascam 2488
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Chapter 7, page 45 talks about erasing partitions permanently.
Feb 07, 2011 | Tascam 2488 Portastudio Multitrack...
Error code 3
Straight out of a Tascam 2488 manual...
When editing tracks, you have selected the
same track as both source and destination
for a duplicate operation.
Press EXIT and try again.
Jan 20, 2011 | Tascam 2488 Portastudio Multitrack...
Recording stops and recorder freezes with tascam 2488mk2
this has happened to me too- with different system error codes also not referred to at all in manual !!! i don't know of solution- and have lost the current recording session by having to just turn the device off and hope for the best... i plan on contacting tascam after this project is complete since my unit is still under warranty - GOOD LUCK out there
Jun 21, 2009 | Tascam 2488 Portastudio Multitrack...
Problem with the hdd. check the h/w
I tried everything that I can think of also, so I am going to send it into the shop. I will post what they tell me.
BR
Jul 03, 2008 | Tascam 2488 Portastudio Multitrack...
Instructions
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Nov 10, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
507 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
